Attached is the tuning file just before this happened.
We were tuning B8101 on engine dyno (MAF/NBO2 not present, MAF DTC present);
the steps to cause the problem were this (from my 3 am memory):
- copied B8101 to B8102, B8151, B8152, and I think we forgot to generate coeffs on those 3;
- tried to save file, but that error message popped up.
When I'm trying it now on my laptop I can't reproduce it...
Zones 12..17 defined by rpm 1600..1800 are only 2 cells high. Zones must be at least 3 cells in both directions. That is what is causing the problem.
Maybe on your laptop you have the "Zone edge align" set to 1 or greater. That has the effect of expanding the zones by one cell on each size.
Zone too small:
Zone expanded using "Zone edge align=1"
P.S. I'm still not sure why you couldn't have just elected not to save the file and closed EFILive that way. I don't get why you had to use task manager.
can i put in a request to change the table display format on the e40 stuff.
it's annoying as all hell having the rpm along the top and map on the left, when every other ecu is the opposite way around.
Specifically the 12599861 (1bar & 2bar) calibration. If your in the mood, can you also add the enable flex fuel option, like you did for the e38.
Ah, I see (it was late and we were losing our minds). Thanks.
I'll retrace our steps on my customer's laptop, I want to get you more details of this.P.S. I'm still not sure why you couldn't have just elected not to save the file and closed EFILive that way. I don't get why you had to use task manager.
