my harness was made from scratch by current performance.
it was made to adapt the 2007 6.2L L92 engine with a t-56 to a 1999 4 door blazer.
so where would i get the schematic for both.
i went with the e67 and its on my L92 engine now, but what program should i run
it with
i got everything hooked up, the clusters are working fine now. i'm just trying to get it started with a 2007 ctv-v tune for now because it uses the e67. i need some help here, it really is kicking my butt.
here is the cts-v tune
http://forum.efilive.com/attachment....1&d=1210678918
and the 6.2L VVT tune
http://www.holdencrazy.com/EFILive/T...012614088).tun
I think you will have to do some segment swapping to make it work, I dont know how to do it but from what it sounds like you need an E67 ECM and a T42 trans controller to make it work. Hopefully someone can help you out as you need the E38 6.2L settings in a E67 6L tune...
400 + views and no one knows the big question. did i ask a $$$$ question? everyone wants to know the answer. even me.
some one is gonna make alot of money if they figure this one out. remember that.
This has bothered me for a long time, as a harness builder specializing in Colorado/Canyon Hummer H3 swaps I'd love E67 VVT tune for a T-56, I get requests all the time! and don't have a proper solution!
Hp tuners has a option to enable the VVT in the 07 Cts-v tune but I'm 100 positive that wont actually work? Any production based E67 VVT tune uses 12633264 pcm, and I'm pretty sure even if the codes correct in a 2009 and prior E67 the VVT won't work, as the pcm doesn't have the hardware. Loading a 09 and prior tune into a 2010 12633264 pcm will likely brick it!
I tired a 2010 CTS-v tune, and a 2010 Camaro tune but neither have the class 2 gauges working? As they are CAN based platforms. I've looked at the raw code of the CTs-v and the Colorado canyon code, and they are layed out quite differently, I did my best to offset the code and find the differences in the shifted files, and swapped segments, I did something right as it thankfully didn't brick the PCM! But it also didn't make the gauges work either.. so I'm at a loss with that for now..
The only other option I can think of is using the 2010 Canyon/Colorado V8 OS and trying the automatic/manual switch that hp tuners has implemented but it doesn't seem to work 100 percent engine still stumbles because its not receiving the clutch signal? When coating down, And cruise doesn't work. I'm not sure if this guy didn't try a 08-12 Colorado 0-5 volt clutch switch? And try wiring it to the same positions as a 2.9L/3.7L manual trans Colorado/Canyon
Someone who has a DBF cough..cough Efi live.. can probably determine how to turn on the reverse lockout for the t-56, set from manual to automatic, turn on the 0-5volt clutch switch feeds, for starting and cruise! Or enable class 2 functions and gauge outputs on the 2010 CTS-v file??
Please someone help, I will help with anyway that I can! Bench testing, bin file code changes, you name it.. maybe some cash donations.. would help to efi live? I would be totally happy having to pay 150.00 for a custom OS that efi live sells to make this work... think of all the profits you could make, I know there are guy with S10s, and Colorado/Canyons that would love for this two work!
As a bonus if you go the route of enabling class 2 functions on a Cts-v then you can run a supercharged V8 with all factory functions in a Colorado/canyon, and S10!!
I've exhausted a lot of time and energy into this, I just don't have the know how that the team at efi live has!
All Gen 4 platforms are CANBus based - but different platforms use different methods when Serial Data (Class 2) communications are needed. The most common option seems to be that the BCM handles this task. Serial Data (Class 2) output to the IPC may be enabled on most E67 operating systems.
Yes - all of these may be enabled / disabled on most E67 operating systems. The Starter Control algorithms and Cruise Control algorithms are a bit complicated (and partially interdependent).
There are no real profits for these endeavours when you have to attempt to recoup the R&D costs. I would need to sell 100 packages with a $1000 premium added to the already hefty price tag - just to recover the R&D costs.
It is easier to enable all of the Supercharger control functions in the Colorado tune.
LOL - let me know when you surpass 2000 hours and $100,000.
Lots of great info here, thanks for the fast response
I had no idea that would cost so much!!
You don't have to implement the code into efi's program if that's a hassle at least until we prove that it works? That's the beauty of efi, part of the reason why I like it so much, is that it lets me work with bin files, that I can change the code on, providing we know what to change? There is a chance that just enabling the IPC class 2 output is all that's needed to make the CTs-v or Camaro OS work. Is that something that could be added to efi's program or could you let me know the hex address of the Boolean and or code changes for it, and I'll test it out, and if it works it can be added to efi's program down the road for others to use?
I wish I had a 100,000 to donate to it, but I'm sorry I do not, it feels like a insult I'm sure to offer 150.00 again, but that's all I can afford unless customers want to pay me 99,850 for my harnesses
Anyway thanks again for your time, and thank you EFI live for all the changes that we can make, and for the constant support of newer vehicles, I've done some incredible things with this software, and couldn't be happier with it!
