i just make up a cable. there is only 1 tx port on the wideband. so i wire it into the rx port on the v2 unit.
can't daisy chain as the aem unit doesnt have a rx wire. only tx along wiht analog out and can + / -
yes, but downside is they are being backwards compatible and sending data at the old speed controller speeds, which is noticeable when logging ls1 controllers.
Uh.. yeah. That was me
Who do I talk to to find out what I need to do to get the OBDII interface working with EFILive ?
It gives a huge advantage over analog and serial interfaces.
I should be able to tweak the device response to get it working.
Thanks.
I don't think the EFILive software will allow you to log CAN data from the AEM controller while simultaneously logging data from other CAN controllers.
The V7 EFILive software is hard coded to log data from only a single controller at any one time.
The V8 software will log data from two controllers at a time but only ECM ($7E0) and TCM ($7E2) so you could theoretically set it up as a TCM (assuming the vehicle does not already have a TCM). However, I don't expect the AEM would support the packet-based high-speed logging that EFILive V8 uses. It most likely only supports generic scan mode which V8 does not support/use.
It's not possible to add support for different headers like $7E1? IIRC the header can be configured to anything. Say "$EF1"
Just throwing an idea out.
