2016 E98 Colorado USA
It seems that I'll be stuck with a full after treatment system... Where can I find service regen or parked regen triggers in the software?
Sent from my Nexus 6 using Tapatalk
@GMPX can you shed some light on this for me sir?
No insight?
I think you misunderstood me... I am not able to do deletes... Therefore, I need a way to trigger a parked or service regen. Normally you would need dealer tools to do this, and I read somewhere that other models have the feature on efilive to trigger a parked or service filter regen... If I am stuck with my dpf, I would like to have the ability to trigger the filter cleaning with efilive. And I believe this feature is there, I just don't know where... I looked in the DVT page while connected to my ecm, but the e98 ecm does not show up in the list
Yea I know there are scan tools out for this... I have a launchtech minidiag and I will try that to see if it can do it. Although I read somewhere that the previous generations of big trucks can do this... I was just wondering if it was something that its pending in a new release or if its out already, or if it will even be coming out ever
I have not seen anything but GM equipment that can do a manual regen on GM diesels. There are other tuning products out that have the option but do not work in my experience. I don't expect that this will be a feature with EFI. I would like to have the option myself with EFI for competition events, etc. I use the GM Tech II
