Results 1 to 10 of 16
Thread: ECM Locked
    Aug 2008
    Default ECM Locked
    Attempted to flash in a new tune this morning and it completed a flash but will not start. Attempted to reflashed and get the $0537 Controller is Locked with Custom Key. That is not true at least not from me anyways. I updated recently and did not have a problem flashing 2 days ago. Now the truck is useless. Please help!Click image for larger version.
    Sent from my SM-G920V using Tapatalk
    Probably not much help but did you try a full flash?
    04 LB7
    2010 LMM
    2015 LML
    Aug 2008
    Yes I did. Tried everything etching except disconnecting the battery. I will be trying that soon.
    Dec 2015
    What happens when you check assume lock is faulty and try alt keys?
    Never heard of this happening to the LML before... I think the flash touched something it wasn't suppose to. Did you update efi live since the flash you did 2 days ago?
    Aug 2008
    It comes back as $0537 error, Locked with Custom key. Updated and have flashed once since the update. Today it wasn't successful.
    Aug 2008
    I have noticed since the update it will ask to save a file that wasn't in the process of modifications. I kinda thought that was a little weird.
    Dec 2015
    Rip. Go make a ticket with efi live... They'll probably be interested. Congrats on the first bricked lml that I know of. Well its not really bricked, but somehow I would imagine the memory that stores said key is corrupted. If the corruption isnt something easy like 0000 or FFFF or 8000 or 0101 or 0001 or something easy like that... I doubt you'll ever get in.
    That is very strange indeed, I don't think any tuning software in the world is capable of locking the LML ECM's due to the way Bosch ECM's are designed so I don't know how that would come up.
    I don't know what to suggest other than maybe unhook the battery for 30 seconds and retry. If you didn't do a full flash then there is no need to attempt to recover it via a full flash, a cal flash would be fine.
    Can you please attempt a pass-though cal flash after unhooking the battery for 30 seconds and then send the trace file to support at EFILive.
    Edit: I see you've posted elsewhere you sent the trace files in to support.
    Aug 2008
    I did send those in. I also had Socal connect via team viewer and we went through everything together. I has a reoccurring longterm memory failure code. There is no record of the Vin etc... I just ordered one up and a new license and we can go again. I don't know how it happened. That really is my luck with breaking something or having it fail without even trying to.
    Dec 2015
    Could be worse. Get the new ECM in and the truck wi be happy again.
  1. Looking at the ecm info and os on a locked ecm
    By jlb350 in forum Cummins 6.7L
    Last Post: September 17th, 2015, 05:50 AM
  2. Locked ECM
    By comnrailpwr in forum Duramax LLY
    Last Post: December 15th, 2014, 02:04 PM
  3. ECM Locked
    By bentley429 in forum Duramax LB7
    Last Post: July 22nd, 2014, 02:22 PM
  4. locked ecm
    By SGFastMax in forum Duramax LB7
    Last Post: May 5th, 2010, 05:20 PM
  5. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
