Results 1 to 4 of 4
Thread: How important is smoothing the ve table
    Sep 2003
    Default How important is smoothing the ve table
    after you use your WB to make commanded=actual. Aside from burst knock what other issue can arise....
    Mmm, what 'issues' do you have in mind??.
    Sep 2003
    I dont have any other issues (not that I know of anyway) I am inquiring to see if there would be any problems I may be missing
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Keep in mind that the value in each cell isn't an island- it relates to the cells around it. If a table looks like the Rocky Mountains, it may be difficult to achieve smooth transitions and you may wind up chasing your tail trying to correct a problem that exists simply because of the value gaps between adjacent cells.
  1. ~IMPORTANT~ IMPORTANT things to look at when changing Speedo.
    By wait4me in forum Gen III V8 Specific
    Last Post: April 26th, 2015, 07:43 AM
  2. smoothing spark table
    By smslyguy in forum Gen III V8 Specific
    Last Post: April 12th, 2010, 12:38 PM
  3. VE Table Smoothing Question
    Last Post: July 19th, 2006, 03:24 AM
  4. Smoothing in the VE table??
    Last Post: March 12th, 2006, 06:31 AM
