We can try this out at CPR Engines here in LA (this is where AEM were going to shoot a vid on this feature, I'm not sure yet what/when).
I'd be keen to know if they also have a faster serial protocal too, the aem stuff is pathetically slow compared to me ALM's, it's averaging the data far too much.
The modified sample 30-0333 has been sent to the EFILive guys. Hopefully, they can get it tested in the next couple of weeks.
Once they verify it, I will offer re-flashes for the 30-0333 for a beta period, for those who want to try it.
Yes, the AEM serial output is really slow @ 100ms. It is a leftover. There only to be compatible with the older 30-4100 and 30-2310.
Unfortunately, to change the rate, you need to use the CAN API. Which is not currently available. :(
I'm anxiously awaiting this as well, I need a WBO2 now so I'm going to order one then will have to send it to dr. mike once we get the EFILive configuration sorted!
I have the AEM that Mike sent and I'll be working on the integration next week. If all goes well we should have something to test mid next week.
