Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Question on speed density
    Mar 2009
    Is the code the concern? Or are you trying to run a MAF tune? I would think that turbo would quickly max the MAF range without scaling it.
    Sep 2005
    I need to run my MAF tune for a day and then flash it back to speed density!
    2002 GMC Sierra ECSB
    Turbonetics T7675 6lbs boost, 42lb injectors, Single 4 inch exhaust with Hi-Flow Cats, 6.0 swap, Comp Cam LS9 Cam, EFIlive Tune, E-fans, Snow Performance Meth Kit, soon to add KB Boost a Pump,
    Mar 2009
    Quote Originally Posted by jamesbond2509 View Post
    Try the tune attached below. I adjusted many of the parameters back to stock, there were some very unusual things in your tune. PE fueling was set to stoich, idle timing tables were very high for such a small cam, injector flow rate should be a flat line (manifold referenced) unless you are not using the factory fuel regulator, etc. Do a compare and you can see the changes I made.
    Do you have wideband? Can you go a log of maf freq vs LTFT or Wideband BEN?
    Are you on PT.net? Your screen name look familiar.
    There were a lot of things different than stock, there's a lot going on there...
    as LastCall alluded to, it is best to start from stock and to edit only those tables that need to be.
    Try LastCall's tune, and post some logs.
    Sep 2005
    Hi Silly question - How do I open the .ctz file.
    Its been over 12 years on the PT.net forum - seen quite a few mods! And you?
    Mar 2009
    Default Question on speed density
    The Ctz format replaced the bin format a few years ago. Sounds like you have an old version of efilive. There should be a "check for updates" in the Help Drop down menu. I would start there. And then check for updates on your BBX/V2 firmware in the eFILive scan and tune application. Those two things should bring you up to date.
    Cool. I've been on there about the same amount of time. Since the days of it being a subforum on ls1tech. Time flies.
    From V7 tunetool, go File->Open and select the .ctz file.
    Or, setup your Windows to associate .ctz with the V7 tunetool, then you can double-click on a .ctz file.
  1. Speed Density
    By jamesbond2509 in forum Gen III V8 Specific
    Last Post: August 30th, 2014, 03:55 PM
  2. Speed Density Question
    By Brad Kimbler in forum Gen III V8 Specific
    Last Post: July 30th, 2013, 10:23 AM
  3. Speed density
    By catman3126 in forum Petrol / Gas
    Last Post: July 15th, 2011, 04:18 PM
  4. Speed Density
    By Yortt in forum Gen IV V8 Specific
    Last Post: December 1st, 2008, 01:11 PM
  5. Question about Speed Density and dual spark map
    By agreif in forum Custom Operating Systems
    Last Post: May 6th, 2006, 08:37 AM
