Results 1 to 10 of 13
Thread: disable rear O2's
    Default disable rear O2's
    Hi Guys,
    Up untill now I have never tuned a car myself, just used the flashscan V2 and efi live software to do data logging etc, and send those files over to a tuner who did the tuning for me.
    I do however get the question very often if I cant turn of the check engine light in cars that have only had an exhaust upgrade. To me that sounds like a simple adjustment, but I don't know.
    How would I be able to do this myself?
    Thanks in advance
    You disable all the DTC's for the rear O2's (table C6001) and you disable the MIL for the same (C6002).
    Thank you for the info.
    How do I get to the tables? Connect the car to my laptop -> start efi live tune tool, and than?
    Mar 2009
    Quote Originally Posted by Hammink Performance View Post
    You will need to read the ECM or edit a copy of the tune if you have already have a copy of it. Go to Engine Diagnostics, there are two sections. One for DTC Enablers and another for DTC MILs. Then do a cal-flash only of the tune.
    Yes, correct, connect laptop->V2->ECM, open V7 tunetool, go Flash->Read PCM Calibration... when it has finished reading, go File->Save As and save it with a filename.
    Then make your edits...
    Then go File->Save As and you should see the filename with _nnnn appended (where nnnn is an incrementing number), and save it with this new filename.
    Then Go Flash->Program PCM Calibration (i.e. a cal-only flash) (if it requires a VIN license follow what it says to assign one and then repeat Flash->Program PCM Calibration)... wait for it to finish, then follow the instruction regarding the ignition key (turn off for 15 seconds).
    What year/vehicle are you doing...?
    Thank you guys for that info!! I will definitely try this!
    Corvette C6 Z06 (year 2007)
    Ok I think I got it, I found both tables, and also how to set everything with O2 to "X not reported" and "no mil"
    Quetion I have though is: do I also disable all the ones labeled HO2S?
    Also I am unable to save the file, is it because I have to purchase this? http://www.efilive.com/licenses/tuni...tuning-option#
    After I bought this I will only need VIN licenses in the future correct?
    Actually, it is sufficient to set them in C6001 to Not-Reported", and there is no need to edit C6002.
    Question I have though is: do I also disable all the ones labeled HO2S?
    Yes, any that mention "rear" O2 or HO2.
    V7 tunetool should let you save the file, post a screenshot showing why it won't save...
    do you have a FlashScan V2 with GM option...? If you do, then each time you flash a new ECM (previously unflashed by your V2) it requires a VIN license.
    doesn't your V2 already have GM option (how else have you done E38 logging otherwise)...?
    Yeah I can log ecm's no problem, and I can also flash them after buying the vin license.
ID:	20249Click image for larger version.
  1. Looking for some help with rear o2's
    By TJWells in forum E37, E38 & E67 PFI ECM's
    Last Post: April 26th, 2012, 01:53 PM
  2. Deleting Rear 02's
    By Gordy M in forum General (Petrol, Gas, Ethanol)
    Last Post: December 30th, 2009, 07:54 AM
  3. rear o2 function?
    By smslyguy in forum Gen III V8 Specific
    Last Post: October 26th, 2009, 10:53 AM
  4. Disable rear o2 sensors?
    By Dlong in forum Gen III V8 Specific
    Last Post: January 6th, 2007, 11:16 AM
  5. rear axle max torque and rear prop shaft numbers
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 04:10 PM
