Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: September 2016: EFILive Beta Test Release
    Nov 2005
    V7 tunetool Save As is not incrementing the _nnnn at the end of the filename.
    Save as and Ctrl+T, and Save tuning file for AutoCal and Shift+Ctrl+T all add the 4 digit suffix for me. Do you have any more information on reproducing this?
    Cindy
    Quote Originally Posted by rcr1978 View Post
    Doubled checked the car today the service suspension message goes away after it sits for a little bit, not sure why the module would take a while to settle down though.
    Thanks for letting us know.
    Quote Originally Posted by BlackCPG View Post
    Paul -
    I'm still having issues with pass thru logging in V8. Same symptoms as the last update. I attached a trace file. Attachment 20246
    I also noticed under OBD status the OS number is now 0. In the full flash status window, the first two digits of the OS are swapped. It reads 35xxxxxx, and it should read 53xxxxxx.
    The trace file did not show any attempt to connect/scan any controller. Can you please supply me with some error message or description of what is not working?Sorry if you've reported it before, if there is a post that you've already made about it, just link me to that post.
    Can you post a screen shot of the OS not showing correctly? And a trace file that you saved from the EFILive Control Panel after displaying the OBD info.
    For V7 only:
    The sequence number won't increment unless you are saving a completely new file that was just recorded. If you open a file and then do "Save As" (any number of times) it will use the same name and not increment the sequence number.
    That is just an unfortunate consequence of the way the V7 Scan tool was originally designed.
    V8 Scan, V8 Tune and V7 Tune will (should) increment the sequence number on all "Save As" operations.
    Oct 2011
    https://forum.efilive.com/showthread...-Release/page2
    about half way down. I sent you an email with everything else.
    03 6spd
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Cannot upgrade any CME OS to CSP4. Option to upgrade is not available under the "upgrade OS" tab. Reverted back to public release software and option is available.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    I just opened up three different CME OS's (one a C&C the other two pickups) and the upgrade option is showing. The only thing I can think of is the USB driver didn't install correctly when you upgraded, I think the upgrade option doesn't show unless V7 can talk to a V2.
    Jun 2011
    re-installed the beta software and now it is there. Must have been the drivers.
    423-506-7427
  9. #19
    Phew! Cheers.
  10. #20
    Ok, it was me that failed...
    my filename was 12212156_0007.tun
    and when I did Save As, the new filename was 12212156_0007.ctz
    and this is why the _0007 was not incremented to _0008 (because the filename/extension is different);
    now after saving as _0007.ctz, when I do Save As again, I now see the next increment _0008 (with the .ctz extension), and now the increments work properly.
    See, it was me --> <-- .ctz
  1. July 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: September 5th, 2016, 03:18 PM
  2. May 2016: EFILive Beta 3 Test Release
    Last Post: June 6th, 2016, 07:30 PM
  3. April 2016: EFILive Beta 2 Test Release
    Last Post: April 30th, 2016, 08:49 AM
  4. April 2016: EFILive Beta Test Release
    Last Post: April 9th, 2016, 03:46 PM
  5. April 2016: EFILive Beta Test Release
