Results 1 to 10 of 14
Thread: Help with first COS upgrade
    Mar 2015
    Default Help with first COS upgrade
    Hi,
    I have a hot LS1 with ITBs and want to use the COS5 for its TPS VE capabilities
    If I understand correctly I have to full reflash the 12225074 OS File and than reflash the original tune file on top, however I cannot find the 12225074 OS.
    Can someone help me? Its an automatic.
    THANKS!
    Regards,
    Paulo
    Mar 2015
    Ok that wasn't so hard... I found it here
    https://www.dropbox.com/sh/4ydh5wltk...+12225074).tun
    My car currently has a 09381344 OS so not compatible with the upgrade. I believe I need to copy the tables to the 12225074 File but there are many tables that don't match, more parameters, etc... Is this a problem or should I just change what I can and leave the rest alone?
    Regards,
    Paulo
    This is what I do:
    I flash in the new OS and see if the engine runs... most times it runs reasonably...
    the few that it runs poorly I then tune it a little and/or copy the tables that are significantly different...
    either way, it's going to be tuned again with COS5.
    Mar 2015
    Joecar,
    Thanks yet again for your help- however cannot full flash either the 1222507 or the COS5 - it just does not allow me to select the full flash button.
    Any idea why that is?
    Did you read the 12225074 file from that PCM...?
    Disconnect the scantool.
    Mar 2015
    Scan tool was not connected.
    Original ECU file is 09381344 . 12225074 file came from the dropbox link I posted...
    If 12225074 was not read from PCM then the PCM is not 0411...
    Mar 2015
    Excuse me but I didnt get that. What do you mean with 0411?
    Am I trying something impossible?
    part # 12200411 PCM.
    If 09381344 was read from your PCM, then 12225074 should flash right in...
    try again doing full flash of 12225074... post screenshot.
  1. New to EFI LIVE and struggling with COS upgrade
    By Cyrperformance in forum Gen III V8 Specific
    Last Post: July 8th, 2015, 12:07 AM
  2. Help please, PCM in dead poll will not take flash, cos 5 upgrade
    By johnmaster in forum Gen III V8 Specific
    Last Post: September 11th, 2012, 03:15 AM
  3. First time COS upgrade, lost.
    By Cody@LoveFab in forum Custom Operating Systems
    Last Post: September 15th, 2011, 07:28 AM
  4. am i an idiot? how do you upgrade to COS on E40???
    By rubbersidedown in forum Gen IV V8 Specific
    Last Post: March 17th, 2011, 11:49 AM
  5. For those who upgrade to a COS or have severe surging at idle
    By RacerChris in forum Custom Operating Systems
    Last Post: November 18th, 2008, 04:03 PM
