I have just fitted a new cam. Its quite a large cam so its affected the running a lot. It runs fine, little lean nothing an AutoVE will not sort out.
I am trying to sort the idle out.
It will idle and holds at 800 as expected but after a rev or slow down from speed. I have sorted out the fueling in the VE for idle and this has helped a lot. but I assume I need to sort out the spark table. it ticks over at 65-68KPA should I increase the spark to match similar to 30-35 ish. (27degrees I think).
Which spark table is it? is it the Base Spark table. B5932 B5933?
Anything else I need to think of?
Also on start it really struggles with out any throttle. is this a fuelling issue or is this my throttle body needing a larger pilot hole?
anything I should particularly log? I am starting to trawl the forums but any help would be good.
