Results 1 to 10 of 19
Thread: DTC P0300 and P0174
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    Default DTC P0300 and P0174
    Hello all. It has been about 5 years since my last post. I have an LSX 376 (E38) mated to a 4 speed automatic (T42) in a 68 Camaro. Ian you may remember me!
    In any case, it has been throwing all kinds of codes after 5 years of running awesome. I changed everything mechanical. MAF, Throttle body, injectors, Coils, O2 sensors, wires, lifters, air filters, electronic gas pedal, you name it. Since I have not programmed for so long I was pretty clueless how to hook it all up again.
    I was able to record a tune today. The passenger side bank is clearly missing and the exhaust smells like way too much fuel unburned. My tuner who made final mods 5 years ago is too busy to help now. But he thinks my computer may be bad.
    Any help would be greatly appreciated!
    Your log shows HO2S11 (Bank1, B1, left bank) voltage staying high, indicating overfueling on B1...
    it might be caused by faulty NBO2 sensor on B1, or leaking injectors on B1.
    Dec 2007
    What Joe said .
    Hey Ian,
    How's it all going...?
    I just read what I wrote and my spelling is bad enough to make my grammar look poor.
    Mar 2010
    Thanks guys. Its nice to hear from you all. I will replace the sensor and resend a log. Injectors have been changed.
    Dec 2007
    LOL great thanks Joe. Your spelling & grammar looked fine.
    Hey Ian,
    Mar 2010
    Hello guys. Here are two logs from today with a new O2 sensor in bank one. First is relatively cold. Number "4" is after warm up. The injectors were new a couple of months ago but perhaps they are still a problem?
    Thanks in advance!
    Patrick
    B1 O2 sensor voltage shows it being less responsive compared to B2...
    Mar 2010
    I will go through the wiring on the B1 O2 sensor but is it likely this is a computer issue?
    Swap the O2 sensors B1 with B2 and see if the problem follows the O2 sensor or if it stays on the bank.
  1. P0171 & P0174 SC 2010 Camaro
    By opcode in forum E37, E38 & E67 PFI ECM's
    Last Post: July 26th, 2016, 10:19 AM
  2. p0300 help
    By Gregs in forum General
    Last Post: February 3rd, 2012, 05:42 PM
  3. P0171 and P0174 codes. Please help
    By JoshH in forum E37, E38 & E67 PFI ECM's
    Last Post: November 3rd, 2009, 05:23 PM
  4. P0300 Code In Idle
    By sheamus in forum Gen III V8 Specific
    Last Post: October 7th, 2009, 01:31 PM
  5. P0171, P0174 Banks 1,2 lean
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: September 5th, 2006, 08:49 PM
