My #150th
2016 Malibu Limited
After ECM tuning has theft light
B101E security code not programmed
Even back to stock with GM dealer toys :( still same light
Please help
Do I need a new ECM
My #150th
2016 Malibu Limited
Please help
Do I need a new ECM
8.7 @ 84 (1/8 mile) bolt-ons
Which ECM type is that model using?
It is not an issue I have heard of before.
E39a
Anything out of the ordinary with tuning it? Was it locked after tuning?
No it was and is fine except for the code and associated light after tuning first time with EFILive.
Have you done that specific model before?
If you have the GM tools then maybe try a theft relearn.
Will do that in a couple hours. Hope it will help as the BCM is setting a code saying security code not programmed in ECM. First time with this particular model but it was just a simple Calibration Flash that caused it. Even tried full flashing after to no avail.
Currently doing immobilizer learn at a dealer this moment
Update: seems to have fixed it. Thank you for the attention and helping me out with this Ross. I will report later to confirm it's still good
Yup works great![]()
Thanks, still very odd that it lost that data after a flash. That area of the ECM is never modified during a reflash.
