https://forum.efilive.com/showthread...ial&highlight=
Here is the thread where I got help setting it up originally.
PN 30-4900
PN 30-4900
00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
I just downloaded the efilive program to my wifes laptop and used that old calc_pids txt . after idling for a bit the volts went to 6.19volts and I verified with my meter its only getting 4.47. I think my AD1 and AD4 are on their way out. I sent it to socal diesel but they said it checks out fine.
Joecar, what I am saying is if you build me a calc_pids txt for me, lets use AD2 or AD3 please.
Ok, I'll edit it to use AD2, see attached...
select the following pids:
- EXT.AD2
- GM.EQIVRATIO
- CALC.WIDEBAND
and then check that the pid CALC.WIDEBAND is completely valid (do rightclick->More Info on it, all the units for it should be valid)... post some logs with these pids.
and then in the charts/gauges use the following pids:
- CALC.WIDEBAND.BEN (use for correction maps)
- CALC.WIDEBAND.LAM
- CALC.WIDEBAND.EQR
- CALC.WIDEBAND.E00 (use for viewing gasoline E0-based AFR)
- CALC.WIDEBAND.E10 (use for viewing gasoline E10-based AFR)
- CALC.WIDEBAND.E85 (use for viewing gasoline E85-based AFR)
Also note that I left the pid CALC.WO2BEN intact... it is mathematically identical to CALC.WIDEBAND.BEN... you can use either.
Thanks!!! I will try these out tomorrow morning.
Here is a short ride to work. The wideband is very close to the gauge now. I will work on it more when my new meth pump arrives. thanks again Joe!
