Hey Joe, how did you 'mix' them? I've thought of doing a mixed model, but Matlab's way of doing it was just so nice and easy it got me lazy![]()
AMEN brother!The fact that our interpolation efforts via different tools/methods came very close to each is a sanity check...
I saw that one interpolation fitted one portion of a curve perfectly, but not the other portion... so I interpolated in segments... I told my tool to interpolate from x1 to x2 using cubic spline, and from x2 to x3 using quadratic, all in increments of 0.0001 or 0.00001 (I got out-of-memory on my 2GB DRAM if I used any smaller increments)... and then I picked the points at the increments for the LS1 tables.
My tool is DPlot, it lets me operate on a portion of a curve at a time... it also forces me to treat a 3D curve as a series of 2D curves in each of the X and Y axes separately... definitely tedious.
1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
Can someone just put a ls1 tune online with the ls3 data in it so we can download and copy and paste data over? Thanks
Thank you
By chance is there any data conversions for the 12613412 injectors? Supposed to be 50lbs and used in the 2010 to 2013 6.0 flex fuel trucks
97 K1500, 383, 4L60E, Whipple, Stock 14 Bolt with 3.73, EFILive V2, 0411, Marine, #42 Injectors, H-Boost, LC-1, Coming Soon: Intercooler, Trutrac, 4.11 gears?
03 K2500HD, 8.1 and Allison, Stainless works long tubes, Intake mods
