Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: Known Issues With Current Public Release
    Default Known Issues With Current Public Release
    Latest updates (released as an auto-update):
    • EFILive V7 software: V7.5.9 Build 318 (Updated Dec 29, 2016)
    • EFILive V8 software: V8.2.4 Build 312 (Updated Dec 29, 2016)
    • Boot Block: V2.07.007 (Feb 07, 2014)
    • Firmware: V2.07.109 (Dec 23, 2016) (Updated Dec 29, 2016)
    Replaces these previous releases:
    • EFILive V7 software: V7.5.9 Build 317 (Updated Dec 23, 2016)
    • EFILive V8 software: V8.2.4 Build 311 (Updated Dec 23, 2016)
    • Firmware: V2.07.108 (Dec 23, 2016) (Updated Dec 23, 2016)
    Updates are described here: What's New
    Until the official download page is updated, the latest Dec 29th software update can be downloaded via these two direct links:
    EFILive V7.5 Software - V7.5.9.318 (108MB)
    EFILive V8 Software - V8.2.4.312(78MB)
    Issue 1:
    Workaround:
    None.
    Issue 2:
    Workaround:
    Issue 3:
    When flashing a Cummins ECM if the reflash fails and an attempt to reflash the controller in 'recovery mode' is made the software will ask for a new license.
    Workaround:
    Fixed in Dec 29th update.
    Issue 4:
    Programming device settings on FlashScan and/or AutoCal may fail.
    Workaround:
    Fixed in Dec 29th update with firmware V2.07.109 and V8.2.4.312.
    Issue 5:
    Double clicking on a calibration in the list of V7 calibration differences no longer opens the clicked calibration.
    Workaround:
    None, will be fixed in the next update.
    Issue 6:
    Some serial wide band controllers' Lambda and AFR values no longer stop at 25 AFR when in free air (or very, very lean condition). Regular AFR/Lambda readings are not affected.
    Workaround:
    Issue 7:
    V8's "test flash" mode for both cal-flash and full-flash does not perform a test erase and flash. It performs a real erase and flash.
    Workaround:
    DO NOT USE THE TEST FLASH OPTION.
    Will be fixed in the next update.
    Did some BBX logging on the E98, is there an update to the sae.map definition still to be done like the v7 software? or will it always max out at 255kpa? (built-in limitation) OR should i be logging something else?
    Changes were made to the MAP PID (in V7 and V8) to implement variable scaling for later model vehicles. Can you send me the log? ([email protected])
    Jan 2009
    When using the EFILive tools F2:Search the Right click function to open file location is broken. Used to work on previous versions.
    Quote Originally Posted by Mitco39 View Post
    It still works on my test system here. Is there maybe some other problem with opening the file? Can you open the file normally?
    Double clicking also works to open the file.
    Jan 2009
    Yeah everything else appears to work just fine. I usually just search a vin and then want to see everything in the customers folder for it. Could 100% be my computer if no one else is having this issue, it can be fickle lol.
    Dec 2015
    I think these PIDs need a C (so we can convert them to F). This is on the E47 Cruze and LML.
    Quote Originally Posted by Snipesy View Post
    Yes, they do. Will get that fixed in the next update.
    Dec 2015
    Also would you be willing to add some PIDs if I threw them your way? (so I can bbx log them)
    i attempted to do some logging today with the v8 scanner with the AEM on an E40 ecu.
    Whenever i attempted to click on the data screen, it would give me a AV error @ address 00965008. read address 00000028.
    Once that came up u clicked ok, then it would come back to infinity. so had to kill program.
    Also got the same error when trying to test a ben pid. except it only came up once. so i could get out of it
  1. Known issues with the October 2015 Public Pre-Release
    Last Post: November 14th, 2015, 10:09 PM
  2. Known issues with the September 2015 Public Pre-Release
    Last Post: September 11th, 2015, 10:46 AM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
