Results 1 to 10 of 10
Thread: 01-07 "Gear Indicator Type" cax
    Aug 2006
    Default 01-07 "Gear Indicator Type" cax
    Many Thanks to Joecar for helping me get this functional. I have made a .cax file for the "Gear Indicator Type" for the 2001-2007 LS1b PCMs. After these are installed you will find the parameter D2400. These .cax files allow you to set the "Gear Indicator Type" to "None", "PRNDL", "P/N". This should be very handy for retrofit projects. I'm sure I don't have all of the operating systems covered for those years but there are a total of 17 operating systems covered in these 5 .cax files. I didn't make any for the 1999 and 2000. I feel it is too easy to upgrade those to the better 2002 operating system. I have them listed as 5 separate .cax files. Follow the directions in GMPX's sticky about .cax files for where to install them into the software. Remember, If you already have any .cax files that cover these O/S, you will have to add the contents of these into those folders. If you don't already have any .cax files for these O/S, you will have to make duplicate copies of them and name them the number of the O/S that they correspond to.
    01-02 covers O/S 12202088, 12208322, 01270003, 01270005, 12212156, 02020003, 02020005
    2003 covers O/S 12579405
    2004 covers O/S 12587603, 12587604, 04073003, 04073005
    2005 covers O/S 12592618, 12606961
    06-07 covers O/S 12587811, 12605114, 12597120
    Jeff
    01-07 G.I.T.zip
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Mar 2007
    Lextech,
    A huge thank you for doing this. I am a novice LS1 swapper, and have stuck with F-body OS's due to this (an the whole A/C type) issue (I don't have Tuner Cat). Having this now in EFI Live should help many other swappers.
    THANK YOU!!!!
    Mar 2007
    Some quick feedback about these CAX files. I tried it for 2002 OS's (12212156) and noticed that the truck, van and corvette tunes (I grabbed them off of the Tune File Depot) showed (PRNDL) for D2400. But when I loaded in a Camaro tune (2002, 12212156 OS, from Tune File Depot), it showed None, instead of P/N. I have used this OS before, and it does work with a P/N switch, but wasn't sure if there was something else going on.
    Aug 2010
    OEM setting on a 1999 - 2002 Camaro tune is None or No Switch (however you interpret this).
    P/N settings in the PCM were generally only used on Gen III vehicles that also used a TCM (Allison).
    Nov 2016
    Does this still work in v7.5.7?
    I download the files, put them in calibrations folder, but don't see any new options.
    Reading other threads is there a cal_link.txt file needed for these?
    Forgive my ignorance, I don't know a lot about EFILive software, just recently purchased it.
    Any help would be appreciated.
    Which OS do you have...?
    The cax file must match the OS.
    The LS1B_Link.ini file is editable, and is used for scantool->tunetool pid linking... i.e. not required for cax purposes.
    Nov 2016
    Ah, that would explain it. Now I get it...duh makes sense. I needed to copy/rename 1221256.cax to 12208322.cax
    Thanks for the hint!
    Quote Originally Posted by saign View Post
    Yes, correct.
    The instructions in the file 01-02 G.I.T..cax say to rename this file to the OS you're using, 12208322.cax.
    You will also have to place a comment symbol # in front of the instructions, or delete the instructions.
    Jul 2003
    Keep in mind that parameter location might not be correct for a different OS when renaming a cax file.
    Yes, correct what Highlander said... do not use for an OS that is not mentioned in the instructions (see post #1 above).
  1. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. 05 Corvette "bogs down" in 3rd gear
    By blazinblue in forum Gen IV V8 Specific
    Last Post: March 30th, 2010, 05:58 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
