Results 1 to 5 of 5
Thread: Error code $0281 2003 LB7, Help!
    Jan 2017
    Exclamation Error code $0281 2003 LB7, Help!
    Was in the middle of flashing my ECM over to Full 1 and accidentally disconnected my AutoCal and now my truck wont start and gives me error code $0281. Did I fry my ECM or is their a way to repair the connection between my EFI Live and my ECM?
    Dec 2005
    Send it to SoCal Diesel, IF a full flash fails it could be bricked
    www.mscservices.net
    Have you tried full flashing it again? If it happened in the first ~15-30 seconds, it likely needs to be sent to be repaired.
    Jan 2017
    I have been unable to try and do a complete reflash due to the error and I am missing the cable that goes from the AutoCal to my computer so I ordered it to hook up my laptop to my truck and see if it registers my VIN. Hopefully it will establish a connection with it.
    Aug 2004
    I fix them all the time. Call during biz hours and i can tell you what you need to do to get it fixed.
    $50 is the cost to fix them.
  1. Error $0281....no data received
    By y2k2z28 in forum FlashScan V2 BB Logging
    Last Post: October 23rd, 2016, 11:08 AM
  2. 04 LB7 won't full flash and $0537 error code
    By 04DMAXX in forum Duramax LB7
    Last Post: March 11th, 2013, 10:13 AM
  3. BBL Error 0281
    By LS2_307 in forum Black Box Logging
    Last Post: January 28th, 2010, 01:10 AM
  4. $0281 error when clearing DTCs - fixed
    Last Post: May 27th, 2008, 11:14 AM
  5. Error $0281 on DTC Clear?
    By Donovan in forum FlashScan V2 BB Logging
    Last Post: May 21st, 2008, 02:59 AM
