Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: Migrate from HP tuners to EFI Live HSV VE 6.2L Heartbeat sc
  1. #41
    Junior Member rich24v's Avatar
    Jun 2011
    Typically the ECM gives you a 10-15 second window to rev up above 4000 rpm. It looks like you got the CASE relearn done.
    Found that I need to do lock/unlock sequence after a pcm flash so that engine remains running after re-start.
    Odd.
    Yup, gave myself the placebo affect there, couple of early starts after flashes were a bit weird, tried the unlock/lock and appeared to work.
    So, now just flash in tune and all is good.
    Making some good progress with help from behold, I'm up and driving on the road now with EFIlive doing the work !!!!.......
    UK spec 2009 HSV VXR8 6.2 LS3, E38, HeartBeat Supercharger running ~9psi,1 7/8" long tubes, cat back exhaust.
    Upgraded cam and springs of unknown specification, all I know is, it's a small cam with no overlap, suits the s/c.
    ATI damper, LS9 twin plate clutch, 548rwhp. twin PLX widebands to twin gauges.
    Currently running dismal HPTuners....NOW DUMPED !, Completed migration to EFIlive and slowly mapping it in.
    628rwhp.....with a lot of tuner help
  2. #42
    Jun 2011
    I'm running a maffless tune in open loop, so trims off etc.
    I still see ltft numbers in the log file, can I be sure they are
    not actually doing anything all the time fuelstatus reports OL ?
  3. #43
    Rich,
    Post your tune file, I'll check that all trimming is disabled.
    BTW: mafless and trimless are othogonal, you can have one regardless of the other (i.e. there are 4 combinations)... sorry, I'm not trying to be pedantic.
  4. #44
    Jun 2011
  5. #45
    Quote Originally Posted by piatzseo View Post
    B
  6. #46
    Jun 2011
    I was seeing ltft data in the logs, but since resetting all trims nothing comes up now which is good.
    Question remains though, when there was data there, would it have influenced anything in the open loop tune ?
  7. #47
    This is tricky... if it was open loop, any trims should not influence, but the trims would have been zero (since it's not correcting, it can't calculate the trims)...
  8. #48
    Jun 2011
    Is the RAFIG process valid for my E38 ?, I had a look at the PDF guide but it mentions IAC pids.
    When I selected the Rafig calc pid and looked at details, it's looking for iac pids.
  9. #49
    Jun 2011
    From this thread:- https://forum.efilive.com/showthread...ed-a-COS/page2
    As per Joecar reply :- MAF-less E38 runs from LO table (i.e. in presence of MAF DTC).
    I had no idea this was the case, a slight revelation for me at least.
    Would it be possible the previous COS MAF-less HPtune would have worked the same way? Ie defaulted to use the Low Octane spark table ?
    In the HPtune, the low octane table is -3 degree across the board when compared to the high octane table.
    Currently this is the same as my LO table.......so perhaps I could jack this up accross the board by 3deg ?
  10. #50
    Jun 2011
    I'm running in closed loop now with fuel trims on ect.
    When logging the wide band data with resultant CALC.BEN_PLX1_E38 , should I ignore all data recorded within CL or
    is this still valid ? ie the trim amounts are netted off first ?
  1. Hp tuners to Efi live
    By madmax4499 in forum E37, E38 & E67 PFI ECM's
    Last Post: October 13th, 2012, 05:51 AM
  2. Is HP Tuners better for gas engines than EFI Live?
    By Texas Edition in forum Petrol / Gas
    Last Post: August 13th, 2012, 08:38 AM
  3. Why 2 Buy EFI Live instead of HP Tuners?
    By DMAX432 in forum General (Diesel)
    Last Post: May 24th, 2010, 05:31 PM
  4. EFI Live / HP Tuners stacked
    By SRT10KLLR in forum E37, E38 & E67 PFI ECM's
    Last Post: December 9th, 2009, 09:52 AM
  5. EFI Live Tuners in Perth?
    By 4wheelin in forum Gen III V8 Specific
    Last Post: September 27th, 2009, 11:38 PM
