Results 1 to 7 of 7
Thread: E38 mafless hesitation after wot
    Aug 2012
    Default E38 mafless hesitation after wot
    Hi
    Iv'e been maffless tuning my VF commodore and seems to go very well
    so far but when you start using wot then cruise at say 1500-2000 it gets a hesitation
    after a wot run but only then.
    Apart from that it drives really good.
    Anyone had this problem any ideas what the cause is?
    Dec 2014
    What's the ramp rate for PE and enrichment, in and out?
    Aug 2012
    PE ramp in 1.10 ramp out 0.01
    PE delay 2000 rpm
    Dec 2014
    Whats the AFR during the problem area?
    Aug 2012
    Need to find the log but I remember afr is fine then goes lean when it happens.
    The cars hesitates/ jolts then its fine.
    Post files.
    Aug 2012
    Actually looks to be timing dropping.
    In the pic it drops to -3 deg.
Name:	VF HESITATION.png
  1. Which PID with E38 ecm to show 100% throttle position at WOT
    By 67SS509 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2013, 01:52 PM
  2. Trying to pin down hesitation (logs)
    By Darkfox in forum Gen III V8 Specific
    Last Post: November 8th, 2011, 05:14 AM
  3. Lack of fuel @ WOT - E38
    By HTMtrSprt in forum E37, E38 & E67 PFI ECM's
    Last Post: August 26th, 2010, 10:26 PM
  4. LLY hesitation
    By LarryJewell in forum Duramax LLY
    Last Post: May 29th, 2009, 09:24 AM
  5. hesitation over buttons and tabs
    Last Post: January 10th, 2005, 08:25 AM
