Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 207
Thread: AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
  1. #171
    dr.mike,
    serial comms is irrelevant when CANbus outshine's it.
    do you want us to test it out on Martin's Camaro (I have to find out where it is)...?
    do you have two units...?
    with high sample rates, I'm sure a lot of shops will run dual 0334's given the tuning advantages.
    ~Moderator~
  2. #172
    Jul 2016
    Unfortunately, I am working with naked PCBs. I will need to re-flash a couple of units to get the car test done.
    I'm not sure AEM will be picking up this change in the 30-0334 ( not an official part number ) . They have already done a bunch of testing on the previous single-channel version.
  3. #173
    Jul 2003
    What about the 30-2340? I have these installed on an engine dyno and I would be interested in getting 8 wideband data to the scan tool.
  4. #174
    Jul 2016
    This trick only works for the x-series widebands, so far.
    Not sure if they are planning to implement it on the other widebands. Or, if it's possible.
  5. #175
    Jul 2016
    OK, I have this week open to do some testing. I can bring the re-flash tool to wherever the Camaro is.
  6. #176
    OK, let me see what's going on with Martin's Camaro.
    Do you have two 0334's...?
  7. #177
    Jul 2016
    I only have 1 full unit. The other is just the PCB. But, I can reflash the units on the car.
  8. #178
    dr.mike,
    I'm sorry for the delay, I've got some family stuff going on.
    Let me find out from Martin when we can test this.
  9. #179
    Jul 2016
    Progress ?
  10. #180
    Apr 2016
    First, dr.mike, thanks for flashing my 30-0333, it's working great!
    I was using it the other day, and I couldn't quite figure out how to log it in the v7.5 scanner, though it worked fine in v8. Is this user error, or just not an option?
    Also, has anyone set up a custom PID that converts lambda to AFR for this setup? I didn't see one in the thread, but I may have missed it.
  1. SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    By Black LS1 T/A in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2016, 04:11 PM
  2. V1, randomly cannot log AFR w/ AEM Uego
    By Tan327 in forum General
    Last Post: February 24th, 2012, 03:40 PM
  3. AEM UEGO wideband Pid?
    By derkscustomcars in forum External A/D inputs
    Last Post: August 8th, 2011, 02:42 AM
  4. An AFR Gauge is a pretty good E10+ fuel sensor
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2009, 07:16 PM
  5. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 09:25 AM
