Page 19 of 21 FirstFirst ... 91718192021 LastLast
Results 181 to 190 of 207
Thread: AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
  1. #181
    Quote Originally Posted by required field View Post
    First, dr.mike, thanks for flashing my 30-0333, it's working great!
    I was using it the other day, and I couldn't quite figure out how to log it in the v7.5 scanner, though it worked fine in v8. Is this user error, or just not an option?
    Also, has anyone set up a custom PID that converts lambda to AFR for this setup? I didn't see one in the thread, but I may have missed it.
    Can you post a log file...
    did you select the pids SAE.WO2S11 and SAE.WO2S21 to log (because EFILive might have the channels swapped)...?
    I have can make a calc pid to show AFR (IIRC, AEM assumes AFR is 14.57).
  2. #182
    Jul 2016
    I'm not sure. But, I don't believe that the 7.5 software was updated to read the 30-0333.
  3. #183
    Quote Originally Posted by dr.mike View Post
    You can, but it'd be the only controller. V7.5 only supports logging of 1 controller at a time, it's a known limitation of it. V8 lets you do 2, which is why you can log a PCM/ECM and the -0333 simultaneously.
  4. #184
    Jul 2016
    That makes sense
  5. #185
    Apr 2016
    I was just using one (and the readings looked correct, just lambda values instead of AFR, compared to the AEM's gauge.) I forget which, was using a different machine I don't have handy at the moment, but pretty sure I was using WO2S21. Will make some new logs and post soon.
  6. #186
    Apr 2016
    It was WO2S11, here's the file, having some trouble importing the BBX file into the v8 scan tool, when I pick the trans controller, AEM UGEO Bank 1 isn't an option in the "select controllers" menu, and when I select it from the drop down, v8 clears the tune file, so that appears to be a bug in the current release.
    E67_0090 - no vin.efi
  7. #187
    I see your pid SAE.WO2S11 behaving like wideband lambda... it is usually about 0.99 and dips down to 0.6 or so.
  8. #188
    Apr 2016
    Yup, that's working; did you have a calculated PID to convert the lambda value to AFR you'd be willing to share?
  9. #189
    Yes, I do...
    did you edit your calc_pids.txt file...? if not then I'll post it tomorrow (I'm not at home at the moment).
    ~Moderator~
  10. #190
    Apr 2016
    I've not touched my calc_pids.txt.
    Thanks!
  1. SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    By Black LS1 T/A in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2016, 04:11 PM
  2. V1, randomly cannot log AFR w/ AEM Uego
    By Tan327 in forum General
    Last Post: February 24th, 2012, 03:40 PM
  3. AEM UEGO wideband Pid?
    By derkscustomcars in forum External A/D inputs
    Last Post: August 8th, 2011, 02:42 AM
  4. An AFR Gauge is a pretty good E10+ fuel sensor
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 19th, 2009, 07:16 PM
  5. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 09:25 AM
