Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: A50/T14 confusion
    Jun 2011
    The T14 is a replacement for the 2009-2010 as well is what I am being told. I unknowingly attempted to flash it as an A50 because that is what it auto detected as. I thought I was replacing like for like so to speak but that wasn't the case. It did begin the flash so that's what has me thinking it was an ok unit before I attempted to flash. I wish I tried to read out the replacement T14 prior to flashing to see if it would read. It licensed fine.
    If it's a direct replacement then when flashed with TIS its going to get the 09-10 OS then and every dealer replacing them would be killing them. I do think this style of TCM (T14)) has been a pos from the beginning and hs been prone to fail even on flashes. All the ones I have done lately have been replacing T14's with a new T14. You would think it would be fine since the 2011 T14 OS worked in the 2010 A50.
    04 LB7
    2010 LMM
    2015 LML
    That is interesting
    I have a spare T14 here that worked intermittently if I can get it to act normal for a bit I will try putting a 09-10 OS in it when I get time. I've already tuned it and it's already broke so it won't hurt my feelings if it takes a shit.
    04 LB7
    2010 LMM
    2015 LML
    Dec 2005
    The replacement TCM T14A is a POS as well.
    I have a bricked on here on my desk, TIS asks for the Hardware Number and even with the correct HW# and VIN entered in the TIS2WEB System it still bricked.
    If you want the TCM to play with Ross I can ship it to you, its a paperweight, if you want a project I have one for you to play around with !!!
    Lemme know.......
    www.mscservices.net
    Jun 2011
    I think at the least we can prevent the software detect them as an A50. I'm interested to see what happens when you try to flash an 09-10 OS in one. If it works fine then I just had a bad egg I would say.
    OK, that is bad, I wonder how that has not fed back to GM / Allison from the dealers to get resolved.
    I have lots of projects already thanks
    Are you guys sure the T14 isn't supposed to be a replacement for the A40?
    Quote Originally Posted by comnrailpwr View Post
    If anyone has a read from one of these T14's I can probably configure the software to not detect or attempt to flash one of these T14's if they just don't work.
    Oh no don't do that the T14's are in all the 2011-2015 trucks, if thats done then we can no tuna anymore
    04 LB7
    2010 LMM
    2015 LML
  9. #19
    Default tonight I tried to full flash a E35B and an A40 and both failed with TIS The TCM is
    With GM controllers the Autodetect typically works based off a list of known part numbers we request, GM might have carried over a P/N that is shared between the two TCM's but they are in fact different.....that would be bad.
    Do you know if the T14 been out long ?
    I tis flashed it twice and it died...again..... What now...????????? Chuck, CoW momentarialy STUCK like a pig.... stuck
  10. #20
    Dec 2005
    The TCM will report a Valid SN#, when attempting to read it states "FLASH RECOVERY" then errors out $0101
    But its alive enough to give up its TCM SN#
    Executing: C:\Program Files (x86)\EFILive\V8\Config\A40_R.obj
    Virtual Machine Started
    Script Loaded
    Script Verified
    Flash recovery mode...
    Please: Wait...
    Script exited with code $0101: No data received
    But its junk for sure.
    T14A hdw # 24256864
    Supposed to be a A40 replacement.......but they are JUNK !!!
    www.mscservices.net
  1. A50/T14 shifter mask
    By vectorbundle in forum Allison 5 & 6 Speed
    Last Post: July 8th, 2015, 11:55 AM
  2. more confusion
    Last Post: October 28th, 2014, 03:00 AM
  3. .cax confusion!!!
    By Lextech in forum CAX Files
    Last Post: September 26th, 2008, 02:25 PM
  4. PID confusion
    By redhardsupra in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2006, 02:43 AM
