Thread: What Background Programs affect EFILive?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default What Background Programs affect EFILive?
    I am of the impression that any virus scanning programs has a negative affect on EFI. Any other programs that I need to be aware of?
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Quote Originally Posted by Chalky
    I run AVG, Win FW and a host of other stuff with NP except-
    Once in a while I have to pull and reconnect the USB plug to get a connection, but only after several logs.
    PowrMax Performance
    100 mm PowrMAF
    Dlong
    Guest
    The only problem I have had is the same as Bruce. When I updated the usb driver with the latest version of efilive the problem went away. I also changed the usb port I was using. So far this is the only problem I have encountered.
    Sep 2003
    Thanks for the feedback. I haven't experienced a problem but thought I would ask just to be informed!!
    Aug 2004
    It is the other companies software that the virus scanners dont like.
    But if you run a spyware program on it while it is running to see why the virus scanners dont like it, you will be supprised to see it accesses alot of stuff that it shouldnt be. That is why Norton and the other Antivirus software dont like it.
    The Antivirus company told me to run a program called Filemon.exe on the program and it would show me why there software dont like peoples tuning software.
    Hmm, On running it, It accesed, my quickbooks folder, my Efilive folder, and a ton more files on my pc both on startup, or any time i made a selection...
    They said it is borderline on being bad.
    Why would a tuning software need to access a banking program?
    I have the file they gave me if you want to check it out..
    I also ran the same program on Efilive just to check it out, and EFIlive was not like The other guys software at all, it didnt check or mess with any files in any other folders or registry entrys. So, something was definatly weird with the other software.
    Its just a good thing for me that i dont use it at all.
    Pretty funny stuff.
    Oct 2005
    filemon is cool and geeky.
    I use it for troubleshooting stuff, you can dl it from www.sysinternals.com
    Go to the "Processes and Threads" link, there are loads of other cool utils here as well as stuff to change your Security ID for cloning etc.
    They have a rootkit discovery tool as well for ultra stealth spyware discovery.
    2014 VF SV LS3 Maloo.
  1. New black background/white text HELP
    By voda1 in forum Lounge
    Last Post: June 2nd, 2010, 08:19 AM
  2. Defuel affect
    By SGFastMax in forum Duramax LB7
    Last Post: May 5th, 2010, 12:59 PM
  3. HSV 06 LS2 Programs
    By Acer in forum Gen IV V8 Specific
    Last Post: April 10th, 2007, 09:16 AM
  4. Can I import HPTuners tunes or other tuning programs into EFILive?
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: March 19th, 2007, 09:10 AM
  5. Programs
    By goldz28 in forum Gen III V8 Specific
    Last Post: December 9th, 2006, 07:31 AM
