Results 11 to 20 of 31
Thread: 2016 Camaro E92 MAF Scale question.
    Redline Motorsports
    Guest
    We double checked the definition of the MAF tables and they are correct, I don't know what GM was thinking with these but it is like they wanted high resolution under 8550 Hz and then beyond that there is a VERY steep linear blend to 15,000 Hz. It could also be computer model generated numbers which is why they look uneven to what we are normally used to seeing.
    It is correct it needs to be rescaled....we've been able to stretch the MAF to 17000 hertz without hitting a wall.
    Thanks Howard.
    Nov 2007
    Thanks Howard. Can someone explain how I rescale it or point me to where I can read up on it. I looked through what I could find in the software and wasn't able to adjust the scale. I don't want to mess anything up so I figured it better to ask. Thanks.
    02 Z06, 573/530rw N/A 416, 10.21@136.12.
    Member SPi's Avatar
    Jan 2010
    Running into this alot now, especially with the 2017's . Can someone explain how to rescale the MAF table. I've done it in other software, can't see how it's done in EFI
    Quote Originally Posted by SPi View Post
    Post your tune file.
    ~Moderator~
    Member SPi's Avatar
    Jan 2010
    Default 2017 Siverado tune
    Here you joecar. Both MAF tables display that large spike
    It's not really a spike... look at how the axis jumps from 9600 Hz to 15000 Hz.
    Are you running out of MAF airflow g/s...?
    Your tune file shows that it supports up to 3000 g/s.
  9. #19
    Member SPi's Avatar
    Jan 2010
    Default Maf
    It's that jump in the axis I am talking about. Is it possible to rescale that axis to obtain better resolution in the higher area? Im not running out Maf, but that big jump makes it difficult to dial it in. Click image for larger version.
  10. #20
    I'm told that GM put that jump in there... it's not possible to rescale the axis.
  1. ol maf tune or ve maf open loop and lambda question
    By 400ss in forum Gen III V8 Specific
    Last Post: February 1st, 2015, 07:12 AM
  2. VE table scale up by how much?
    By queso in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2007, 12:23 PM
  3. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
  4. I need a stock MAF for a 2000 LS1 camaro!
    Last Post: October 25th, 2005, 03:20 PM
