Results 1 to 9 of 9
Thread: How Do I Enable IAT with MAF Disabled?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default How Do I Enable IAT with MAF Disabled?
    Considering trying VE Tune. Trying to figure out how to provide IAT to PCM when MAF disabled. Car is 02 Corvette with 5 pin MAF!!
    EFILive Distributor dfe1's Avatar
    Jan 2005
    Disabling the MAF disables the MAF, not the temp sensor. Just follow the instructions and it will work fine. Don't be discouraged if AutoVE doesn't get you where you want to go. In my experience, it takes a lot of time and patience to dial things in with AutoVE.
    DigitalEFI- EFILive US Distributor
    [email protected]
    678/344-1590
    Sep 2003
    Thanks. I think I became confused when the tutorial indicated to check with two forums for instructions on configuring 5 pin MAFS!!
    Lifetime Member MN C5's Avatar
    Mar 2005
    Quote Originally Posted by dfe1
    ? "takes a lot of time and patience" please explain how that works I've found it to be quick and easy. And the IAT probe is located in the MAF so disconnecting the MAF would disable the IAT sensor and he is trying to read the IAT.
    You'll need a seperate sensor to plug or splice in. You should be able to dial your SD tune in within a hour and 3 or 4 flashes if your doing it properly.
    Sep 2003
    Quote Originally Posted by MN C5
    If I don't have to disconnect the MAF, and with the MAF disabled by changing high frequency fail to 1 MZ, can I assume that the IAT can still be read by the PCM? This seems to be my understanding. 5 pin MAF's do not have to be disconnected, correct?
    EFILive Reseller kbracing96's Avatar
    Sep 2005
    I put a 3 wire conector on the wires going to the MAF on my 5 wire MAF so I could just unplug the MAF part, and with just seting it to fail, I get the same BIN numbers whether it was pluged in or unpluged, so you should be fine seting it to fail and leaving it pluged in.
    Quote Originally Posted by Chalky
    You don't need to physically disconnect the MAF provided the PCM throws any of these DTC's: P0101, P0102, P0103;
    the presence of any of these DTC indicates the PCM is ignoring the MAF and is using only the VE table ("SD" mode).
    If the PCM doesn't throw any of these DTC's, then you need to physically disconnect the MAF; you can do this in several ways:
    a. using a pick, remove just the MAF signal wire from the 5 pin connector;
    b. cut the MAF signal wire and splice in an in-line switch;
    c. get a 5-wire MAF extension cable and cut the 3 MAF wires;
    d. get an adapter cable that already does this.
    (search the LS1tech for this).
    When the PCM is ignoring the MAF, the PCM will still read the IAT.
    I agree 100%. I guess I have been lucky on the 5 wire mafs I have not had to do any of those other steps yet, I have always got the maf to fail. On my 02 vette Im running a custom os without my maf and its still pluged in with no problems.
    Jan 2005
    As has been posted, disabling (as opposed to removing) the MAF doesn't interfere with IAT. As for AutoVE, perhaps I'm not doing it right, but I just haven't had good results. When I look at the BEN map, the max values in most cells are above 1.0, the minimum values are below 1.0 and the average is somewhere in between. When I use the average to adjust VE, it always seems to get things further away from where they should be. I've had better and quicker results by just data logging with the wide band and using that data to adjust VE.
    [email protected]
    678/344-1590
  1. EGR not disabled
    Last Post: January 19th, 2010, 05:11 PM
  2. Anyone fully disabled Pilots?
    Last Post: May 1st, 2009, 04:37 PM
  3. egr enable
    By kostelacd69 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 6th, 2009, 07:01 PM
  4. Wouldn't it be easier to tune with PE mode deleted/disabled?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: March 15th, 2009, 12:16 PM
  5. can tow/haul be accidentally disabled?
    By Superado in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 13th, 2008, 11:46 PM
