Results 1 to 10 of 18
Thread: Fuel Pump Control
    Junior Member jderekt's Avatar
    Mar 2017
    Default Fuel Pump Control
    I am very new to the tuning world and this forum, so please bear with me. Mods please move if in the wrong category.
    I am working with a 98 S10 ZR2 truck, it has a custom built 4.3 with an 0411 pcm upgrade running 02 blazer OS. My question is the fuel pump runs for no less than 30 sec after shutdown. I know the pump will run a few seconds after shutdown, but this seems excessive. Is this normal?? Where in the tune can I find this setting? I have searched but have not found it. What am I missing?
    Thanks in advance for any help you all can provide.
    Derek
    4.3L Vortec
    0411 PCM
    .020 over bore
    Comp 266HR cam
    Comp roller tip rockers
    Volant cold Air Intake
    Mercury Marine intake manifold
    JBA stainless shorty headers
    Borla full exhaust with high flow cat
    How is your PCM and FP wired...?
    Mar 2017
    PCM is Controlling the factory fuel pump relay in fuse block, So using stock 1998 controls.
    Are PCM switched power inputs wired to switched power (and not hot at all times)...?
    ~ by phone ~
    Mar 2017
    Well as far as I know they are. I'll have to check that.
    Sent from my SM-G935P using Tapatalk
    1998 S10 ZR2 Ext Cab.
    4.3L Vortec
    4L60E Auto trans
    0411 PCM and Engine/trans harness
    .020 over bore
    Comp 266HR cam
    Mar 2017
    Was finally was able to get back to this. Switched power pin-out is confirmed, although I did discover going by the pin-out I was originally provided, I do not have battery+ on C1 pin 57. The pin-out I have lists it as unused?
    I do have it at C1 pin 20.
    Switched power is at
    C1 pin 19 ckt-439
    C1 pin 75 ckt-1020 (OFF/ RUN/ CRANK voltage)
    Sent from my SM-G950U using Tapatalk
    4.3L Vortec
    4L60E Auto trans
    .020 over bore
    Comp 266HR cam
    Mar 2017
    Has taken me a long time to get back to this (truck has been sitting a lot) but I've finally figured out this issue. Turns out the oil pressure sensor, which in 98 was still part of the pump circuit, is slow to bleed off pressure. Which keeps the pump running until the pressure drops to 10psi or so. Which means I've apparently got debris in the sensor.....sensor was replaced when motor was rebuilt. So new sensor going in after I purge that oil passage a bit.
    And this circuit is going to be removed to eliminate this completely.
    4.3L Vortec
    4L60E Auto trans
    .020 over bore
    Comp 266HR cam
    Which year/model/vehicle do you have...?
    ( I didn't think that the EOPS was involved in the fuel system )
    Do you have a wiring diagram...?
    Mar 2017
    98 S10 ZR2 truck, and yes I have factory manuals on computer and print versions. It does show it, and I have verified the wiring is as shown in schematics.
    HMP Tiff Hotspot Viewer_98fuelpump.pdf
    Hey, that is cool, shows attention to detail by the GM engineers
    I like that it provides two redundancy paths.
  1. Replies: 12
    Last Post: March 9th, 2018, 06:46 AM
  2. Using the AC relay output to control a second fuel pump
    By ttls1 in forum Gen IV V8 Specific
    Last Post: December 31st, 2013, 11:13 PM
  3. fuel pump control
    By THEFERMANATOR in forum Duramax LB7
    Last Post: August 9th, 2013, 06:13 AM
  4. Replies: 15
    Last Post: May 6th, 2012, 03:20 PM
  5. Replies: 1
    Last Post: September 22nd, 2010, 03:40 AM
