I'm getting a Error $0537 for the 2014 Cadillac CTS-V Sport Twin Turbo for Read 2 T43.
Any idea why it's not pulling the Trans Read.
I was able to pull the factory E92, but Read 2 is says UNLOCKING WAIT, then ERROR $0537
The Error Codes pdf says this:
I've never seen this on an TCM.
$0537 Controller is locked with a custom key. An attempt was made to read or program a
controller that cannot be unlocked using the
standard GM keys.If you know the key that was used to lock
the controller, please use the unlock option
in the EFILive software to unlock the
controller before attempting to read or re
flash the controller again.
So you can read the ECM ok, but not the TCM...?
That is correct. Pull the ECM just fine.
I just brought this car last week lol
Don't know why the device is not reading the factory TCM...
Suggestions?
Very good point.
~ posted by phone ~
No, opening a ticket wont help as EFILive doesnt support that TCM at all. It'd be different if the TCM was supported and a new calibration just needed to be mapped out.
For reference, HPT doesnt support the trans either. Trifecta might, but regardless you'll have to use their software/hardware to flash it and they lock most things too FYI.
