Thread: Throttle body silver to gold settings.
    Lifetime Member 68problemchild's Avatar
    Mar 2010
    Default Throttle body silver to gold settings.
    Hello All. I installed a gold throttle body 90MM (from Silver 90MM) and am getting codes P1516 and P2101.
    I am looking for assistance in locating:
    1. Which two tables to adjust?
    2. Does anyone have the stock settings for a Gold 90MM throttle body?
    It would be great to have a starting point, eg % error and voltage range for a gold blade.
    I did find this info on the board:
    There are differences in the TPS signal output ranges between the silver and gold blade throttle bodies. Firstly, the ECM expects a specific correlation between the 2 sensor signals. For both the gold and silver blade TBs, TPS1 and TPS2 move in opposite directions. On the gold blades both signals have very similar ranges, while on the silver blades one signal has a small offset. If you have codes after swapping to a non OE TB, you would have to change the expected signal ranges or the allowed % error between TPS1 and TPS2.
    Secondly, the ECM correlates specific voltage values to % throttle opening. For example, if 4.0V is considered 100% and the blade hits the stop at 3.9V, it will not be able to achieve the desired 100% WOT position and P1516 will set (predicted TP != actual TP). A work around for this is to reduce the maximum throttle opening by a few % in the throttle response tables.
    You do not have to change the throttle area scalar when swapping between gold and silver blade TBs if they are both 90mm.
    Thanks so much in advance!
    May 2010
    I'm in the same boat i hope we can edit the voltage vs % opening for TB
    I have a problem with 102 TB with LS1B ECM trigering p1516 after releasing the pedale with medium boost but not at WOT
    EFILive Tuner
    Mar 2010
    My gold throttle body range at key on is Min 12.5% - 88.2% Max. Not sure if this helps. Need to learn how to add more pids on to V2. Lol
    Mar 2010
    Changes made by tuner that seem to work thus far.
    B2517 "TCS Throttle Limiter by Input Speed" -98.596170 "Different from cell: 0,0 to cell: 5,8 inclusive."
    B2800 "Throttle Response Map 'A'" -1.364157 "Different from cell: 0,12 to cell: 16,16 inclusive."
    B2801 "Throttle Response Map 'B'" 0.050355 "Different from cell: 0,13 to cell: 16,16 inclusive."
    B2802 "Throttle Response Map 'C'" 0.050355 "Different from cell: 0,14 to cell: 16,16 inclusive."
    C0807 "Throttle Too Low Error" -4.100099 "CAL: 11.00 <-> ALT: 6.90"
    C0808 "Throttle Too High Error" -4.100099 "CAL: 11.00 <-> ALT: 6.90"
    Quote Originally Posted by 68problemchild View Post
    Thanks for posting back.
    Mar 2007
    Do you know if these are all of the parameters that your tuner had to modify, or is he having to make some CAX type adjustments too?
  1. Switch throttle bodies from a sliver blade to gold back to sliver!
    By BLU BYU in forum E37, E38 & E67 PFI ECM's
    Last Post: October 31st, 2016, 08:27 AM
  2. Throttle Tip-In Settings?
    By turbo_bu in forum E37, E38 & E67 PFI ECM's
    Last Post: May 31st, 2016, 07:59 AM
  3. Throttle Body Swap
    By L31Sleeper in forum Conversions / Aftermarket Parts
    Last Post: June 10th, 2011, 12:36 PM
  4. Throttle body set screw
    By 99STEPSIDE in forum Gen III V8 Specific
    Last Post: August 8th, 2009, 06:30 AM
  5. 94-95 B/D Body Speedo Settings?
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2007, 04:14 PM
