Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
Thread: Help tuning out AFM?
  1. #31
    Take a log of the following pids:
    RPM
    MAF g/s
    MAP kPa
    EQIVRATIO or LAMBDA
    LONGFT1,2
    SHRTFT1,2
    IAT
    ECT
    DYNAIR
    DYNCYLAIR
    SPARKADV
    KR
    ~ posted by phone ~
  2. #32
    Also, do you have a wideband, if so which one...?
    ~ posted by phone ~
  3. #33
    Mar 2008
    No Wideband but I will make a few logs tomorrow evening.
    Mine2001 GMC 2500HD EC/LB, D/A. 4in MBRP exhaust, AFE Stage II w/Amsoil Ea air filter, ISSPRO boost/Pyro guages, PPE Boost Valve, EFI Live V2, Maximum OD Stage 2 Trans, Amsoil throughout, AirDog150, modded intake horn.
    540HP/1056TQ
    Dyno'd Danville Performance
    April 5th 2011
    Hers: 2006 GMC Envoy XL Denali, Flowmaster 40 with a bullet style resonator in the back, EFI Live with the help of JoeCar and other great members here.
  4. #34
    Mar 2008
    RPM
    MAF g/s
    MAP kPa
    EQIVRATIO or LAMBDA
    LONGFT1,2
    SHRTFT1,2
    IAT
    ECT
    DYNAIR
    DYNCYLAIR
    SPARKADV
    KR
    ~ posted by phone ~
    Should I drive during the log and if so how would you recommend I drive it for the log?
    540HP/1056TQ
    April 5th 2011
  5. #35
    Mar 2008
    Ok, I went and logged about 21 minutes of driving and some park running. Since my injury, I'm not able to read this the same and make adjustments and its frustrating me that I no longer know what I am looking at. At this point I am at the mercy of Joe and the group here to help me out before I spend the money to have this tuned by someone.
    Here is the log.
    Enovy Log 1.efi
    Thanks for any help you guys can give me. I will be sure to add this tune to the new DropBox that someone is hosting here on the site.
    540HP/1056TQ
    April 5th 2011
  6. #36
    I'll look at your logs and I'll guide you along.
    I hope you're ok.
    ~ posted by phone ~
  7. #37
    The idea is this:
    - filter out throttle transients (which also eliminates VE),
    - make a ltft map to correct the MAF,
    - retest.
    ~ posted by phone ~
  8. #38
    We can then calculate VE from the MAF.
    ~ posted by phone ~
  9. #39
    Mar 2008
    I'm better but my memory and some knowledge is lost due to a head injury. Nothing like learning things you never wanted to forget and remembering the worthless shit.
    540HP/1056TQ
    April 5th 2011
  10. #40
    Ok, do this:
    1. look at table B5001, hightlight the whole table, go rightclick->copy-with-labels,
    2. goto scantool, goto a map letter tab, edit the map properties, on each of the Row and Col tabs click Paste Labels (do this in rapid succession, don't do anything else in between),
    3. on the Row tab select the MAFFREQ pid, on the Col tab select any pid,
    4. on the Data tab select the LONGFT1 pid (for now),
    see if you can get a LTFT map populated from your log.
    ~ posted by phone ~
  1. Cant get 100% Throttle -Tuning E78 ECM 2011 GMC 2500 6.0 HD Truck L96 VVT non AFM
    By 496Stingray in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 2nd, 2015, 11:23 AM
  2. Tuning the AFM on a 2010 LMG
    By Naf in forum E37, E38 & E67 PFI ECM's
    Last Post: January 17th, 2012, 07:55 PM
  3. 2010 5.3 AFM tuning
    By CDN SS in forum Petrol / Gas
    Last Post: April 7th, 2011, 07:31 AM
  4. 07 Tahoe with AFM
    By kkmboise in forum E37, E38 & E67 PFI ECM's
    Last Post: February 18th, 2011, 04:35 PM
  5. HELP!!! AFM won't enable....
    By GAMEOVER in forum Gen IV V8 Specific
    Last Post: January 18th, 2009, 10:50 AM
