Results 11 to 20 of 39
Thread: how to update the VE map to cutom 2-3 bar table
    Junior Member MadBeaver's Avatar
    Apr 2017
    Default Thanx Joe
    Hello again. Here are my tune files. DaHoe_0001.ctzLS1B- hk tahoe stock.ctz
    Apr 2017
    b3605 not found !
    B3647 in the COS replaces B3605 in the GM OS.
    I'll take a closer look later tonite.
    ~ posted by phone ~
    First do this: fix these Out-of-Range parameters:
    - A0001
    - A0002
    - A0012
    - A0013
    howto (there's a trick to it): set each of them to max-1, save tune file, exit tunetool, reopen tunetool, set each of those to max.
    ( note: this step is important )
    Second do this:
    your B3647 show EQR 14.63...!!!
    to fix this:
    - go Edit->Properties->Display and set fueling units to EQ Ratio;
    - exit tunetool, reopen tunetool;
    - set table B3647 to: below 80 kPa = EQR 1.00, above 80 kPa EQR 1.175;
    - set table B3649 same sa B3647;
    - save tune file.
    Note:
    EQR is simply 1/Lambda
    AFR is calculated as StoichAFR * Lambda or StoichAFR/EQR
    Also: Edit->Properties->Display and set VE units to g*K/kPa.
    Also set your PE Enable B3616 to 60% below 3200 rpm, 35% above 3200 rpm.
    Are you running boost...? If yes then set B3613 to 105kPa, and use PE B3618 to control fueling during boost.
    You should disable LTFT Correction B3801.
    Set C6001 P0101,2,3 to A:1 Trip.
    If you're correcting VE table, note that MAF is enabled, and vice-versa.
    Quote Originally Posted by MadBeaver View Post
    Well I Have updated to the custom OS following the EFI Tutorial manual. Truck wont start, seams like it wants to but no Go. Smells rich when cranking. EFI tutorial said it is a good base map. Is that true. Any advice?
    Thank you
    Second do this:
    This is why your engine does not start (see post above how to fix it).
  9. #19
    Apr 2017
    you are awesome ! I am going to work on these things mentioned. The truck runs great, somehow I got it tricked to work with 10 psi on one of my BAD previous tunes.. 14:1 AFR so not running it but she is smooth. running garret tp38 turbo large intercooler 48lb/hr injesctors exhaust intake valves etc I am really happy just need to get the mapping right now. I am new at tuning but quick learner. really appreciate your help!! Joecar is THA Man
  10. #20
    Apr 2017
    DaHoe_0001.ctz this is from today still no start, other not much changed tunes start the truck no problem. can you see more craziness in here
  1. Updating 2 bar to 3 bar map sensor
    By badls1 in forum Gen III V8 Specific
    Last Post: November 2nd, 2015, 12:40 PM
  2. 3 bar Map ?
    By RandyWS6 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 7th, 2015, 01:50 PM
  3. Tuned as a 2 bar MAP but is actually a 3 bar
    By barbermi in forum Gen III V8 Specific
    Last Post: March 22nd, 2012, 03:24 PM
  4. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 12:27 PM
  5. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    Last Post: April 27th, 2010, 05:21 PM
Tags for this Thread
