So, the ABS light is on. No codes, Fluid full. Can the V2 detect ABS codes from PCM? I changed my front wheel bearings about 2 years ago and did not look at the sensors.
I am wondering if they are coasted with metal trash or if something else is going on? I noted that when I unplug the passenger sensor, I get no changes. when I unplug the driver's side, the brake light comes on.
is the V2 right there are no codes or is it not able to read them?
