Results 1 to 4 of 4
Thread: DBW issues
    Sep 2013
    Default DBW issues
    I have a LQ4 was a DBC but I converted over to a DBW with a TAC controller part number 12588923 and its pedal assembly. It works till it hits 85% throttle and then it closes the throttle blade and will not open till you cycle power on the ECM. I did a complete reflash of the ecm with a 2003 LQ4 and DBW. Also it has an idle issue but the engine is all stock. I have added the tune file and a log file if anyone can look at them and show me what might be going on with it.
    Check what DTC P1518 means (seen in your log).
    It seems like the TPS and ETC sanity tables may be being exceeded (see tables in Engine Diagnostic segment).
    For DBW, log the pid GM.ETCTP.
    I see in your log where the throttle is shutdown at 85%... but the RPM has already dropped to zero before this... you have other additional problems.
    Sep 2013
    I have figured out the problem with the DBW. I was using a Red/Blue ECM and a TAC and Throttle body from a Green/Blue ECM. Once I reflashed a Blue/Green ECM it started working correctly.
  1. DBC to DBW.
    By camaro68 in forum Gen III V8 Specific
    Last Post: August 17th, 2017, 02:42 AM
  2. Remove DBW
    By jojonoumea in forum Gen III V8 Specific
    Last Post: June 8th, 2016, 11:30 PM
  3. DBW Issues
    By catman3126 in forum Gen III V8 Specific
    Last Post: February 24th, 2014, 09:19 AM
  4. dbw to cable TB
    By driver456 in forum Conversions / Aftermarket Parts
    Last Post: June 28th, 2011, 01:02 PM
  5. DBW Issue
    By sparkinak in forum Gen III V8 Specific
    Last Post: August 23rd, 2008, 01:45 PM
