Quote Originally Posted by dlandsvZ28 View Post
Thanks for the explanation. Helpful indeed.
Out of curiosity - probably will stick with current 347 short block rather than upgrade to an GM Crate LS2 376 built for boost. But if I did so then I would have to use a later PCM. So a 'what if question'.
Because I have a 98 pcm and my car is ATI supercharged, my tuner converted my maf tune to sd and installed a 2 bar map sensor- something about reading tables and cells for higher boost levels not available in the 98 pcm - fooling the numbers is best way I can explain because of limited capability of the 98 pcm to read higher boost up to 15 lbs. Tuner uses EFI live.
So if I was to repin my 98 pcm over to a 99 to 2002 PCM then I assume I would use one V1 license because the pcm is no longer a 98 but instead a 99-2002 pcm.
Yes, if you switch to a 512kb LS1B PCM (99-02), you will need to use a license to tune the vehicle. But, you open up all the COS options (I'm betting your tuner has halved the VE and spark tables to make it run with boost) which allows for a lot more control over fueling while in boost.
You could use your V1 to do this if you so desired, just leave 1 license on that cable when you go through the upgrade it. However, the V2 allows the same functionality PLUS you can remotely log/scan/tune with it. If you licensed it to your V1 now, you could copy this license over when you do your V1 -> V2 conversion, otherwise you would have to use a license on both the V1 and V2 if you wanted to use both cables.
