Results 1 to 7 of 7
Thread: wont rev up on trans brake
    Aug 2016
    Default wont rev up on trans brake
    new tune and makes great power but wont rev up to the 2 step while on the transbrake. and is sluggish off the starting line till about the 100ft mark. 5.3 turbo . heres my tune and a log while trying to get up to the 2step thanks for any advise.2step2.efi5.3s10s480.ctz
    Some weird stuff is going on...
    your log shows at 170 kPa your injectors are only at 30% DC... looks like something wrong with your PCM possibly... can you do a full flash.
    also something wrong with your wideband, it is way off.
    Which V7 build version are you using...?
    Aug 2016
    It's a v1 version 7.5
    Aug 2016
    sorry more precise info
    V7.5.7 build 309
    Can you update your V7 software to this: 2017-Beta-Release-10
    ( I think it might fix your wideband problem )
    Your PE is a little too lean for boost, you should be commanding something like AFR 11.5.
    Your spark timing is also too advanced for boost.
    Your VE tables look wrong.
    What is the stall speed of your torque converter...?
  1. 2012 Vette 6l80 tune in older trans for faster tap up tap down and rev matching
    By RD in SD in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 24th, 2015, 01:36 PM
  2. 4L80E with Trans Brake, no reverse, line pressure?
    By tdmkr496 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 20th, 2014, 06:27 AM
  3. Manual Trans Rev Limit E38, 2010 Camaro?
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: May 9th, 2012, 10:17 AM
  4. Is there a rev limiter parameter for when the brake is depressed(2010 Camaro)?
    By 2010 Bumblebee in forum E37, E38 & E67 PFI ECM's
    Last Post: May 6th, 2010, 06:21 PM
  5. cos 5 with trans brake and n2o
    By minytrker in forum Custom Operating Systems
    Last Post: March 7th, 2007, 05:14 AM
