Results 1 to 10 of 10
Thread: E67 VS 0411 opinions
    Apr 2007
    Default E67 VS 0411 opinions
    I have done several swaps with various LS engines, the latest swap will be using a 2013 Camaro ZL1 supercharged 6.2. I am VERY familiar with the 0411 controller, however I am thinking of using the E67 controller that was used with the engine to begin with. I currently have several 0411 controllers and several harness parts for it. I have nothing for the E67. My question is, in the long run is the E67 going to be a much better controller thus worth the extra effort? I can already see that just loading in a factory tune as a base is an advantage, I will be running a T56 so I don't think a transmission controller is needed, and there seems to be enough aftermarket throttle pedal assemblies to make the DBW a non-issue. The reluctor is also a non-issue as I have the engine out and a few of either variety on hand.
    Let me know what you think....Thanks!
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    I'd just use a factory CTS-V E67 ECM + OS for a manual and call it a day. You can control everything like it's in the vehicle, just kill VATS and be on your merry way. Run a CTS-V pedal (or a compatible one) and use the factory throttle body. Advantages over the 0411 are that it is already tuned for it (just fine tuning required), you can control the heat exchanger pump via the ECM, and control boost via ECM vs external boost controller (imagine there are others as well).
    There is a learning curve for tuning a Gen IV ECM vs a Gen III, but it's not horrible and the same principles apply just takes a little different approach.
    It's hard to say... E38/E67 are more advanced/faster/complex than 0411, they are a bit harder to tune.
    Aug 2006
    You can't run a 58x engine on a 12200411 PCM. The 0411 will run 3x, 4x, 24x Crank Reluctors.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Mar 2009
    I run a 411 PCM in my own truck with a 2 bar OS and I like it.
    I've tuned several LSAs in swaps using the E67 controller. The advantages to using it are provisions for the side mounted knock sensors and proper calibration data for them, boost control solenoid, IAT 2 temp sensor, and Intercooler pump control. You also have a ton of maf resolution so an SD tune is not required but an option if you want to go that route. I also think the factory narrowband controls work faster and more accurate than the 411's.
    You should be able to run the 58X reluctor with a 411 PCM with the converter box.
    Apr 2007
    Yes I know I have tuned a couple and the virtual VE table had my head spinning, there were just minor mods so there was nothing crazy to them, but still, I was not very comfortable.
    Thanks!
    Apr 2007
    Quote Originally Posted by Lextech View Post
    Jeff
    Yup, know that! I have the tool to swap them. Thanks!
    Apr 2007
    I think having looked at these answers I am going to go ahead with the E67 controller. With the changes I am making to the engine it will need tuning, but I can at least start with a stock supercharged tune. Going to have to come out of my safe zone eventually. BTW Wanted to look at a stock tune for one, where is Holden crazy?
    Thank you all!
    HoldenCrazy has been replaced by the DropBox: EFILive Tune Repository DropBox
    Apr 2007
    Thanks again!
  1. Opinions on LS1 with retro look
    By GMPX in forum Gen III V8 Specific
    Last Post: July 30th, 2012, 10:32 PM
  2. Spark table opinions
    By kostelacd69 in forum Gen III V8 Specific
    Last Post: April 14th, 2011, 04:34 PM
  3. need opinions on tuning!
    By cburchel in forum General (Petrol, Gas, Ethanol)
    Last Post: November 23rd, 2010, 01:53 PM
  4. Replies: 0
    Last Post: July 8th, 2008, 02:12 PM
  5. wbo2 opinions
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 30th, 2007, 04:16 AM
