Results 1 to 2 of 2
Thread: 2014 Sierra HID and DRL issue
    Sep 2017
    Default 2014 Sierra HID and DRL issue
    I purchased a 2014 Sierra SLT that was originally owned in Canada. It has the BCM flashed for Canada law requiring the DRL's to be on if the vehicle in in gear. The vehicle has the LED strips across the top of the lights and the actual headlights come on as DRL's. The light switch also has a spring in it to automatically go to the "auto" position. The daytime running lights are causing a problem with the HID headlights. I can hold the light switch to the off position and start the vehicle and the lights stay off. When I continue to hold the switch in off and drop the vehicle into gear, the DRL's come on. My question is 1) can the BCM be reflashed to behave like a US Sierra or can I purchase a BCM already flashed? 2) Can I take the switch apart and remove the spring allowing it to be manually set to the setting I want? Any suggestions or potential fixes? Appreciate the help!
    Wrong forum.
  1. Replies: 0
    Last Post: November 2nd, 2015, 04:14 PM
  2. 2014 E92 5.3 sierra throttle response mods
    By efiexpress in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 30th, 2015, 04:37 AM
  3. 2014 Sierra 5.3 tuning help?????
    By TorqueMonster007 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 4th, 2014, 02:55 AM
  4. 2014 5.3l sierra magnacharger
    By 400ss in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 26th, 2014, 04:42 PM
  5. Cant open e92 2014 sierra tune file on v7
    Last Post: April 10th, 2014, 11:51 AM
Tags for this Thread
