Results 21 to 30 of 42
Thread: SAE.MAP not working properly with C7Z06
  1. #21
    Quote Originally Posted by Move'n Up View Post
    I don't have that options anywhere??
    Attachment 21511
    Later versions of V8 have that button available.
    If it is already running, you can open the EFILive Control Panel window by clicking on the FlashScan icon in the System Tray near the clock on the Task Bar.
    If it is not already running, you can start it by either starting EFILive V8 Scan and Tune or by starting the control Panel directly from the Start menu.
    If you start the Control Panel directly from the Start menu then you will also need to manually close it when you're done by right-clicking on the FlashScan icon in the System Tray and selecting Exit.
  2. #22
    Oct 2015
    Yep, found it in the task bar shortly after I posted that. Files are on the way via email.
    Let me know if you need anything else, happy to contribute.
  3. #23
    Thanks for the files. It showed the problem. When transmitting the MAP scaling info from FlashScan to the PC, the MAP kPa scaling and O2 Amp scaling were getting accidentally swapped around.
    I edited the *.pld log file using Hex Workshop and swapped the scale parameters to how they should have been and it fixes the problem. The MAP value in that log file now reads 26-31kPa at idle and 96kPa with engine off (at end of log).
    These are the changes I made to the log file with Hex Workshop.
    I will fix the problem in the V8 pass-thru software so that the correct scale values are stored with the correct PIDs.
  4. #24
    Oct 2015
    Great, glad the scan and log files were helpful so that you could find and fix the problem.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  5. #25
    May 2010
    Thanka Paul
    Looking forward to the new update
    EFILive Tuner
  6. #26
    Please can we check the same thing with SAE.LAMBDA...?
    Please can all of you post some logs containing SAE.LAMBDA ( EQ_RAT in V8 )...?
    Thanks.
  7. #27
    Oct 2015
    Thanks.
    Joe do you want both files as well?
  8. #28
    Log file is sufficient for now.
  9. #29
    Oct 2015
    Here's a log with EQ_RAT for you Joe.
    E92-2.pld
  10. #30
    Thanks.
  1. SAE.MAP reading lower than expected in C7Z06
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 19th, 2017, 05:13 PM
  2. E67_AFRATIO_DMA is not working properly ?!!
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2015, 03:43 PM
  3. DSP output not working properly
    By hot-dog in forum Duramax LB7
    Last Post: April 10th, 2014, 02:11 PM
  4. E39_AFRATIO_DMA is not working properly
    Last Post: June 20th, 2013, 04:51 AM
  5. Cruise not working properly after tire calibration
    By Max Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2012, 12:26 PM
