# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
*UNITS
#Code System Abbr Description
None None "" "No units"
K Metric "K" "Degrees Kelvin"
R Imperial "R" "Degrees Rankine"
# Add slot definitions here
*CLC-00-032
factor 0 4 .0 "{GM.EQIVRATIO}=1"
*CLC-00-110
factor 0.5 1.5 .4 "{GM.EQIVRATIO}*{EXT.WO2LAM1}"
*CLC-00-120
factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT2})/200+1"
*CLC-00-220
factor 0.5 1.5 .4 "iff({CALC.CL}, {CALC.LTFTBEN}, {CALC.WO2BEN})"
*CLC-00-273
C 0.0 100.0 .1 "{GM.DYNAIRTMP_DMA.C}"
F 40.0 220.0 .1 "{GM.DYNAIRTMP_DMA.F}"
K 280.0 380.0 .1 "{GM.DYNAIRTMP_DMA.C}+273.15"
R 500.0 680.0 .1 "{GM.DYNAIRTMP_DMA.F}+459.67"
*CLC-00-300
% 0.0 100.0 .2 "{SAE.MAF.gps}*{CALC.DAT.K}/{SAE.MAP.kPa}/{SAE.RPM}*3445.2/displacement()"
VE 0.0 2.468 .4 "{SAE.MAF.gps}*{CALC.DAT.K}/{SAE.MAP.kPa}/{SAE.RPM}*15"
*CLC-00-305
% 0.0 100.0 .2 "{CALC.SELBEN}*{CALC.VEN.%}"
VE 0.0 2.468 .4 "{CALC.SELBEN}*{CALC.VEN.VE}"
*CLC-00-310
gps 0.0 400.0 .1 "{GM.VETABLE_DMA.VE}/{CALC.DAT.K}*{SAE.MAP.kPa}*{SAE.RPM}/15"
*CLC-00-315
gps 0.0 400.0 .1 "{CALC.SELBEN}*{CALC.MAFN.gps}"
*CLC-00-430
VE 0.0 4.0 .4 "{GM.DYNCYLAIR_DMA}*{CALC.DAT.K}/{SAE.MAP.kPa}"
*CLC-00-435
gcyl 0.0 1.0 .4 "{GM.VETABLE_DMA.VE}/{CALC.DAT.K}*{SAE.MAP.kPa}"
CALC.CL F032 CLC-00-032 factor Tuning "Closed Loop (based on EQIVRATIO)"
CALC.WO2BEN F110 CLC-00-110 factor Tuning "BEN from WB"
CALC.LTFTBEN F120 CLC-00-120 factor Tuning "BEN from LTFT"
CALC.SELBEN F220 CLC-00-220 factor Tuning "BEN selected from LTFT or WB"
CALC.DAT F273 CLC-00-273 "C,F,K,R" Tuning "Dynamic Air Temperature"
CALC.VEN F300 CLC-00-300 "%,VE" Tuning "Calculated VE, not corrected"
CALC.VET F305 CLC-00-305 "%,VE" Tuning "Calculated VE, BEN corrected"
CALC.MAFN F310 CLC-00-310 gps Tuning "Calculated MAF, not corrected"
CALC.MAFT F315 CLC-00-315 gps Tuning "Calculated MAF, BEN corrected"
CALC.VEDCA F430 CLC-00-430 VE Tuning "Calculated VE (from DCA)"
CALC.DCAVE F435 CLC-00-435 gcyl Tuning "Calculated DCA (from VE)"
