Results 1 to 8 of 8
Thread: RR control panel won't launch after latest 7.5 update
    May 2016
    Default RR control panel won't launch after latest 7.5 update
    I just installed the most recent V7.5 update and now the RR control panel won't launch.
    Illegitimi non carborundum
    May 2016
    Found the problem.
    What was the problem/solution...?
    Are you connecting using Native USB or Virtual Com Port...?
    May 2016
    I rebooted my laptop a 2nd time and it started working. I'm not really sure what was going on. Everything works perfectly now. I am using the virtual com port settings.
    May 2016
    My laptop is running Windows 7 ultimate 64 bit. I am thinking it was an issue with my laptop and not the software.
    ok, understood.
    Just FYI: I'm using Native USB to connect to my RR.
  1. Weird Cruise Control Issues since latest update...
    By analog56x in forum Cummins 5.9L
    Last Post: September 15th, 2015, 10:50 AM
  2. Launch control help.
    By bluecumminss in forum Cummins 5.9L
    Last Post: February 17th, 2015, 05:07 PM
  3. Launch control
    By thomasldavies in forum Gen IV V8 Specific
    Last Post: July 25th, 2010, 04:48 PM
  4. Can Not Display Rr Control Panel...
    By TFZ_Z06 in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 4th, 2008, 05:37 AM
  5. Cant use v2 control panel on pc
    By cLuBsTa in forum FlashScan V2 BB Logging
    Last Post: January 7th, 2008, 05:49 AM
