Results 1 to 7 of 7
Thread: No throttle in gear E38 - 6L80
    Oct 2017
    Default No throttle in gear E38 - 6L80
    We have a vehicle we have just fitted a LS3 - 6L80 into. A conversion we have done many times before. This car was a L76 - 6L80 before. We have swapped out both the engine, trans and E38 ECM but not the loom. Engine starts and revs correctly. Once the vehicle is put into gear it will not accelerate. The throttle pedal becomes some what unresponsive. Take the vehicle back out of gear and throttle works again. The E38 is programmed for auto trans. There is no fault codes, tap up, tap down works correctly. Just no throttle. That doesn't mean the throttle is the issue rather than something I assume in programming that restricts its operation once reverse or drive is selected. Has anybody come across this before?
    Moved to E38 section for better traction.
    Oct 2017
    Joe,
    I am confused if this help advice or a statement. Can you explain further?
    Oct 2017
    Thanks Joe. I understand, you moved the post to E38 section. Took me a minute. Thanks
    ( I thought more people doing E38 stuff would see your thread if it was moved to the E38 tuning section of the forum rather than staying in the Scanning General section )
    ( sorry, I'm a linux kernel programmer by trade , I can be terse sometimes )
    Oct 2017
    We have had our issue sorted. We had done nothing wrong but apparently the particular operating system in the E38 is a bit temperamental. Changed the OS and bingo. Everything works as it should.
    ok good to hear it worked out.
  1. L98 6l80 e38 conversion in to jeep wrangler
    By JCA in forum Conversions / Aftermarket Parts
    Last Post: October 16th, 2017, 11:52 PM
  2. Truck uses Throttle Follower P/N Tables when In Gear
    By ferocity02 in forum Gen III V8 Specific
    Last Post: April 8th, 2013, 03:20 PM
  3. Replacing a 6L80 with a 4L80 in pontiac G8 - E38 controller
    By g8lover in forum Conversions / Aftermarket Parts
    Last Post: August 23rd, 2012, 09:22 PM
  4. 6l80 won't go into 6th gear above 75mph or so in tap shift mode
    By whypave in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 10th, 2012, 08:07 PM
  5. Throttle Cracker Airflow in Gear
    By DaleMX in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2005, 03:06 AM
Tags for this Thread
