Results 31 to 36 of 36
Thread: 4L60E Reference Material
  1. #31
    Sep 2012
    the wires were pulled out of the connector leading into the tranny on my 93 2500 gmc sierra. the truck wiring harness side !
    is there a color code diagram for the truck side ? with pin numbers ? so i can rebuild the 11pin conector
  2. #32
    Default Shift curve relationships
    PT shift table relationships:
    basic relationships:
    1->2 curve should be above 2->1 curve;
    2->3 curve should be above 3->2 curve;
    3->4 curve should be above 4->3 curve;
    additional relationships:
    3->2 curve should be above 1->2 curve;
    4->3 curve should be above 2->3 curve;
    this can be summarized as: the curves cannot cross anywhere;
    if they cross anywhere, then you will not be able to predict what gear the PCM selects when the operating point hits the cross.
  3. #33
    Aug 2012
    A few broken links here. I just found this and printed it into a spiral book. Great reference
    http://www.grail-ss.com/GRAIL%20Webs...ETechGuide.pdf
  4. #34
    Nov 2014
    so the tcc is commanded at light cruise in 4. and at wot in 2. and 3. gears?
    any idea if the above links are now perhaps accessible somewhere else?
  5. #35
    Quote Originally Posted by dian View Post
    No, only in cruise in 3rd or 4th, and never during WOT/PE or high load, and not in 2nd (2nd transitions to 3rd rather quickly).
  6. #36
    The link from post #33 above is broken, the destination file of that link does not exist anymore (error 404 file/directory not found).
  1. Collecting links to scattered material...
    By joecar in forum Tutorials
    Last Post: March 31st, 2021, 11:39 AM
  2. 4L80E Reference Material
    By joecar in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 18th, 2015, 05:41 AM
  3. Calculating IFR slope with no vacuum reference?
    By 67SS509 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 25th, 2008, 03:59 AM
  4. Modified Tune For Reference Please
    By Dennis93TA in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 4th, 2007, 03:57 AM
  5. HPT marketing material
    By DrX in forum Lounge
    Last Post: August 7th, 2006, 09:22 AM
