Results 1 to 7 of 7
Thread: Looking for stock tune LLy
    Nov 2017
    Default Looking for stock tune LLy
    long story short the truck had a bully dog on it when we purchased. it would not uninstall and the tune I pulled off my ECU was not a stock one. I am looking for a stock tune for VIN 1gchk23245f909949 now i did find one that was close to the versions located on the Cal check on TIS but the fuel system and speedometer versions are different. I am still learning on this platform so not sure how much this will matter.I am hoping some one could educate me on how the different versions work and impact on the tune.
    One that came off of the truck
    Operating System: 15228758
    Engine Operation: 15904640
    Engine Diagnostics:15879109
    Engine: 15879103
    Fuel System:15879098
    System: 15228743
    Speedometer:15233749
    The one i found on Diesel Place
    Engine Diagnostics: 15879109
    Engine: 15879103
    Fuel System: 15879099
    System: 15228743
    Speedometer: 15233751
    Jan 2010
    You Know, I had an issue with my LLY and I believe it had some sort of aftermarket tuner on it at some point. It appeared stock with all the available EFI Live tables as well as had the most updated calibration in it.
    I ended up getting the truck re-flashed through some one with access to TIS. Flashed booth the ECU and TCU and it resolved my issues. You might wanna consider going that route.
    Junior Member Donovan's Avatar
    Sep 2007
    There are some vin specific cal settings which may be a factor. For example long beds have bigger tanks. I thought you had someone flash you back to stock already? I honesty would do that first although since your os is the same you may be able to create templates off the one your are working on. Also didn’t you already buy an aftermarket tune?
    E35A/A40 + DSP5
    Nov 2017
    I had a buddy try to reflash with ‘‘tis and no luck that is why I am looking for a stock one.
    I thought they could just lock the tune but not need to lock the ecu. This is why I am trying to put together a stock tune to have. He was able to update the tcm with the latest but not the ecm.
    Jan 2010
    If you did not intentionally lock it, Check you V2 settings, it may have been set to lock the Tune when flashing the calibration file.
    This has happened in the past
    Here you go
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Nov 2017
    Thank you !
  1. Replies: 14
    Last Post: November 14th, 2017, 03:10 PM
  2. Need stock tune for lly. ASAP!
    By Quinton in forum Duramax LLY
    Last Post: September 24th, 2017, 03:25 PM
  3. cant pull stock tune off lly
    By crash85 in forum Duramax LLY
    Last Post: February 28th, 2015, 02:12 PM
  4. 2004.5 LLY Stock Tune File Needed
    By BigTexas68 in forum Duramax LLY
    Last Post: May 20th, 2013, 02:23 AM
  5. Can't read stock tune out of LLY ECM
    By JoshH in forum Duramax LLY
    Last Post: March 13th, 2012, 09:38 AM
