Results 1 to 5 of 5
Thread: VIN Won't Flash LS1B VIN 000
    Apr 2017
    Default VIN Won't Flash LS1B VIN 000
    Hey everyone.
    When I flash this controller the VIN has all zeros. I'm not getting any error codes and otherwise the flash seems to work fine. This is using V8 on a bench harness or in the vehicle, full flash or cal. I can't get the VIN back on the controller. I can only find one thread related to that and he said it was fixed by updating. I've updated firmware and software and I don't know what else to try.
    Any help would be highly appreciated.
    Which V8 build version are you running...?
    Apr 2017
    V8.2.10 is that the build number or am I looking in the wrong place?
    Jul 2003
    Change vin with 7.5 scanner
    Apr 2017
    That worked. Thanks for your help!
  1. V2 Flash Scan Vin Licenses
    By Age08 in forum FlashScan V2
    Last Post: October 3rd, 2017, 07:46 AM
  2. Bricking LS1B PCM by Changing VIN
    By minytrker in forum Gen III V8 Specific
    Last Post: December 14th, 2015, 02:02 PM
  3. changing vin on lmm to my suburban vin. is this doable?
    By Madspeed in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2015, 03:14 AM
  4. what vin do i use the ecm vin or the dash vin
    By nycblazer in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2008, 04:31 AM
  5. Can i flash my VIN in a used PCM?
    Last Post: September 18th, 2007, 12:23 AM
