Results 1 to 10 of 15
Thread: Unrecognised PCM
    Dec 2017
    Default Unrecognised PCM
    Hi, this is all new to me but I think I might need a stock tune ctz file for my 2011 L77 VESS manual ute ? I bought it second hand & it already had an exhaust & an OTR mafless tune. I have just fitted a bigger cam & bought a Flashscan V2 to help tune the thing but I got this little alert. Can anyone help a newbie out ?
    Go Help->About
    which version does it say...?
    Start with the latest software from EFILive.com, both V7.5 and V8 are needed. Try to re-open the file then and see if it opens.
    Dec 2017
    Go Help->About
    I downloaded & ran both V8 & V7.5 versions. It says V7.5.16 as pictured.Whenever i try to data log or anything other than read the flashscan display says required config files not found.Will have another go in a moment.Click image for larger version.
    Last edited by Stonecold; December 22nd, 2017 at 06:30 PM. Reason: add more detail
    Dec 2017
    Nevermind have sorted it out.Thanks anyways.
    What did you do to get it going...?
    Dec 2017
    I had to add E38 to the list of enabled BBL controllers & load some confiq files into the flashscan to enable logging. I still get the unrecognised pcm message but I think that is because of my OS number which i have seen come up in another thread posted on here. I can now read and log but I don't seem to be able to access any files for tuning,that being said I could be doing something wrong as I'm new to all this. I sent my .ctz file to support as I didn't see my OS number listed on the reference pdf at the efi live website but that pdf hasn't been updated since 2014 by date indicated....hmm. I'm guessing I will need a stock .tun file and do a full flash?
    Wait for Support to get back to you.
    Lifetime Member limited cv8r's Avatar
    May 2005
    It may have previously been tuned with HP Tuners and have one of their custom OS's in there which could explain the unrecognised PCM message
    It's all good until it goes "Bang"
    Dec 2017
    What support? Ha
  1. Unrecognised PCM 2011 HSV Clubsport
    By MarkR8 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 23rd, 2017, 09:20 PM
  2. Unrecognised PCM
    By 808diesel in forum Cummins 6.7L
    Last Post: August 26th, 2013, 11:33 AM
  3. Unrecognised PCM
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2012, 12:06 PM
  4. Unrecognised PCM
    By JoshH in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 9th, 2007, 07:34 AM
