Results 1 to 9 of 9
Thread: Wide Band O2 to ECM unused EGR
    Dec 2017
    Default Wide Band O2 to ECM unused EGR
    Can anyone tell me where on my 2012 Chevy Silverado 5.3L flex fuel ECM the EGR pin is?
    I have an AEM wide band kit hooked up and I was told I can wire it to the ECM unused EGR signal 0-5 volt but I can not find the Pin Outs for my ECM
    And where can I but the pins and tiny boots?
    You can do it that way if you want to (IDK what the EGR pin is).
    Why don't you want to log it from your FSV2, it has 0-5V analog voltage logging ability (4 channels)...?
    Dec 2017
    EGR is just what I was told, but then no explanation other than it is under used.
    What is FSV2?
    Sent from my Pixel 2 XL using Tapatalk
    FlashScan V2, based on your other threads it appears you have an AutoCal which is tied to BBP's FlashScan V2. The EGR port was commonly used with the old NBS Silverados and not trucks of your generation as the PCM/ECM hardware is different. I don't know if there is an EGR pin that is actually active for the E38 ECM (what your 2012 Silverado has).
    I didn't realize you have an AutoCal...
    Erik is correct, newer ECM's do not do EGR anymore... you might try the ACP (air conditioner line pressure) input, if you're not using AC.
    Dec 2017
    Yea still using ac here in AZ but I could disable it to get this beast tuned.
    Do you happen to know what pin that would be?
    Sorry, I don't have a wiring diagram.
    Dec 2017
    ECU pin 85 is the unused EGR pin
    logs the wideband 0-5 volts
    May 2014
    Depending on the wideband you're using, make sure you double check and correct for any voltage offsets in the signal so your reading is accurate. I saw 0.1-0.2 AFR error when I did this initially with a LC-2. It's my understanding the new AEM X series gauges correct the analog output automatically.
  1. I need help with my wide band
    By isak81 in forum External A/D inputs
    Last Post: January 8th, 2012, 03:46 PM
  2. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  3. The Wide Band....how do we really know...
    By Redline Motorsports in forum General
    Last Post: January 8th, 2007, 06:51 AM
  4. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
  5. lm-1 wide band
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: January 6th, 2006, 08:39 AM
