Is there any option for a VATS disable patch on a 2017 LT1 using the E92 ECM? I don't see the vats disable or starter relay disable anywhere. This is a conversion were doing, 2017 camaro LT1 into a street rod.
ECM E92
OS 12678648
ECM E92
OS 12678648
They are only done when people request them, I'll get you sorted out ASAP. How far off are you trying to fire it up?
Thank you so much, I'm modifying the harness right now hoping to be ready by the end of the week or first part of next week. Im also open to suggestions for a tach and speedo hook up if you would know any.
Do you need the tune file?
No need for the tune file, I'll post a .calz file up here when it is done.
Any luck with the calz file? Not trying to rush, just wondering how it was going.
HD release got in the way sorry..and I am supposed to be having some time off over Christmas (yes, why I my PC on!!)
Can you give me a time frame when you are really ready to fire it up?
Its actually ready to fire up now. Just need to change a few things in pcm to get it running, Vats and starter diagnostic shutting me down right now. I'm not in a "super rush", I understand it takes time.
I had a problem yesterday with 2016 Corvette C7 M7 that does not has the VATS tab ?
so I could not disable VATS just applying the VATS patch
EFILive Tuner
Just checking in to see if there was any progress on the calz file yet?
Oh no I'm sorry I totally forgot about this. I'll get on to it today.
