Is it possible to use the 0334 with Swingtans E38 VVE dial in guide cant seem to get all the pid's I need to work.
Can anyone recommend a retailer for the 0334 with delivery to Victoria Australia?
I found them for sale locally at carmods Australia for anyone interested.
Hi guys, i have successfully installed my new 30-0334 and got it working in the car (2016 VFII Redline Commodore) and have also added the WBO2 into EFILive scan and tune using the instructions that came with the gauge under the F2: Scan icon.
My problem is that when i select my PID list to program to the FSV2 in BBX, the AFM WO2S11 PID under GPM-Generic is not available for me to add to my PID list and program to the FSV2, so i can't log the AFR.
Any suggestions?
So, here are a couple of screen shots to help explain what i am trying to achieve.
https://www.dropbox.com/s/3rb9nsbcyu...03.07.png?dl=0
When i select my E38 controller as in the screenshot above, i cannot select the PID from the AEM controller and combine the two to get the AEM WBO2 in with the rest of the PID's of the E38, to then program to the FSV2.
https://www.dropbox.com/s/6mcgj1dix8...03.30.png?dl=0
You need to double click the E38 under the "BBL Enabled Controllers" and add the AEM WB02 as the TCM. It should show as "E38&AEM" under the "Modules" column. In your screenshots, you have the E38 setup as one controller and AEM as a 2nd controller, they must be setup as a single controller (think of it as an automatic vehicle with E38 as ECM and AEM as TCM).
Thanks scarab, I will give that a shot after work tonight.
OK, so i took Scarab's suggestion and made a test list of PID's to log (thanks Scarab), the problem i now have is that the AEM is reading in mV on the FSV2 and i cant figure out how to change it to AFR.
The gauge itself is reading AFR, its just in the EFILive software it is recording it as mV.
All help greatly appreciated.
see screen shot in attached link.
https://www.dropbox.com/s/shjkhswsn9...41.13.png?dl=0
Trying to upload screenshot below.
You have it already, the EQ_RAT11 is the one you need. It is in Lambda, you would need to either be ok viewing in Lambda or writing a calculated PID to convert Lambda to AFR. When you're logging it, press the Enter button on the V2 keypad to switch between the different units. It may already be there, I usually log with these in V8 directly.
