Results 1 to 7 of 7
Thread: Few Questions on a v2
    Oct 2017
    Default Few Questions on a v2
    Please bare with me new to all this tunning. I have recently purchased a v2 and have been messing around with it and i plugged into a gm vehicle and went to the tune tab brought up the table and turned off the afm. Now my next step it says there is a vin license on it do i select the cal flash tab and hit cal flash to flash that tune back on it? confuse on this part like I said new to all of this thanks in advance
    Yes, do a Cal flash, it will ask you to use the vin license.
    Are you doing this from the V7 tunetool...?
    Oct 2017
    ya thats correct whats the differnce between a cal flash or a full flash
    cal flash: flashes only the calibration tables.
    full flash: flashes the operating system and the calibration tables (you should use this only when changing OS).
    Oct 2017
    Ok so any small changes just do a cal flash then?
    Quote Originally Posted by bensalz1911 View Post
    Yes.
    Non-OS changes (small or large): yes, do a cal flash.
  1. LMM DSP questions / Power questions
    By Djreversal in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 18th, 2011, 08:06 AM
  2. New and have questions.
    By disturban in forum Vortec V6/V8 Specific
    Last Post: May 14th, 2011, 12:58 AM
  3. 3 questions
    By eboggs_jkvl in forum E37, E38 & E67 PFI ECM's
    Last Post: October 22nd, 2010, 02:46 AM
  4. V2 questions
    By aaronr in forum Custom Operating Systems
    Last Post: February 18th, 2009, 04:33 PM
  5. V1 questions
    By Frozen WS6 in forum FlashScan V1
    Last Post: October 4th, 2008, 01:29 PM
